For what Architects are compensated, you would be wise to choose the shortest and cheapest program you can.
That kind of thinking will make you a lifelong peon. The only place worth being in architecture is in its aristocracy.
This is by no means guaranteed by a master?s degree from a top school ?just as attending an Ivy League school doesn?t guarantee you?ll be elected President-- but you might look at who?s been elected recently, and you might check Wiki to find out where your architectural heroes went and the degrees they got. Look up: Norman Foster, Robert A.M. Stern, Richard Rogers, Frank Gehry, Charles Gwathmey, Michael Graves, Rem Koolhaas, Richard Meier, Robert Venturi, Demetri Porphyrios, I.M. Pei, Robert Campbell?
For every one of these guys, 5000 stiffs graduated the same schools with the same degrees and are doing formulaic churches and crummy shopping centers in the suburbs or ?worse?backstabbing their way to the number 4, 3, or 2 spot in a big firm. So there are no guarantees if you take their path. But you?ll also find precious few top-rank architect who didn?t.
DO NOT pay for a Master's Degree unless you have your heart set on teaching.
This is bad advice. Get a Master?s degree if you can. Two reasons:
1. The most sophisticated architectural concepts are bandied about in architecture programs, and you basically need to be an intellectual if you want to be in the architectural elite enumerated above.
2. When the economy goes south --as it has recently?architectural work dries up. If you?re an employee, you get laid off and if you?re self-employed you have to close your office. That?s when it?s good to be able to get a teaching job. I weathered the last two recessions by teaching. I had to commute from Charlotte to Rhode Island, but I survived. Would you rather be teaching or in the unemployment line?
Get the bare minimum formal education for what you want to do (in most cases, a BS in Arch. will do).
This is even worse advice. Less education is never good, and more education rarely bad. Education gives you a competitive advantage wherever you find yourself.
Btw, in my state, a BS in Arch. Doesn?t even qualify you to sit for the exam.
If you are a scary talented designer ? go for the big degree.
Yes.
If you are like 90% of people in the profession, you will always do production work and will learn far more on the job.
True, and if you?re like 99% of aspiring actors, you?ll be waiting tables.
It's true that production work is learned on the job. After you've learned it (three years), the rest of your career should be spent avoiding it.
Go for the brass ring, kennedy.
