Everything else you said makes perfect sense, particularly given the other freight customers that I didn't know about (and thanks for all the detail!). I also like your suggested reconfiguration around JFK/UMass, although I wonder if it might be simpler just to add a flying junction south of Savin Hill, at the location of the old Harrison Square station, where the Ashmont Line turns west, freeing up the Braintree tracks north of there?
- Savin Hill is a very low-ridership station (2nd-lowest on all Red), so full-on mainline frequencies are a big waste there.
- For taking ailing trains out-of-service from the subway you need crossover options and most conflict-free pick of empty platform berths at a location closest to the portal in order to dump passengers and/or minimize delays reversing to Cabot Yard. Busting JFK down to a single island platform is going to hurt recovery time from a disablement by lots vs. being able to pick which nearby platform berth will be unoccupied the longest.
- Not a lot of room between Savin Hall and the Freeport St. bridge to split tracks and flyover. And extremely little lateral room in that stretch. Flying over closer to Clayton St. split is going to punish someone with an ill-advised slow zone by tacking on a graded incline in close proximity to a curve.
All of CTA's remaining grade crossings are grandfathered. And they've been trying to get rid of their last remainders for years, but can't come to a consensus on how to do it. While there's no FRA-type body lording over rapid transit, the NTSB would have a field day with that so there'll never be any allowances for new-construction HRT to have public crossings. As late as the 70's they were still considering building the Orange Line to Reading with some of the Western Route's grade crossings retained...but that was several lifetimes ago for the phenomenon of distracted driving/walking.But the quoted above is interesting. I'm not surprised to hear in general, but if memory serves, the CTA in Chicago has a couple of heavy rail grade crossings -- I think on the Ravenswood Line? That was what I had in mind when suggesting the same here. How does Chicago make it work? (Or am I misremembering?)
Quincy losing their one-seat to Kendall and Harvard is an immediate disqualifier politically, because nothing else can approximate ease of access to Cambridge. Forced transfer to a sardine can at JFK is an unacceptable substitute. Also...RER makes no assumptions that NSRL is getting built, so the wholly-future Porter possibility is irrelevant today. You must implement RER frequencies or the Link has no basis for getting built, and if RER frequencies must pre-date the Link to get it built then so must the fix for OC single-track. You can't sell RER or the track fix on the back of immediate transit loss to Cambridge or you'll get skinned alive in Quincy.Follow-up idea: in a post-Link (with an OC portal) Regional Rail world, what's the argument against converting the Red Line tracks on the Braintree Line to mainline, and running Regional Rail on them, through-running the tunnel downtown out to Porter and Waltham, or some other northside line? You still get the peak-express track, especially for south-of-Middleboro service, but get a lot more capacity overall, plus a faster ride downtown for Quincy and Braintree riders.
Also, in terms of raw frequencies...not all 3 OC lines qualify for the maximal 15-min. RER headway we call "Indigo" for the 128-turning lines. See my previous post for how hyper-dense service is differentiated from suburban service (or pull up the TransitMatters website where they make the same exact distinction in bullet form) while still following RER operating principles. It's probably only short-turns to Brockton can support all-day demand at 15-min. headways. The other two lines, and service past Brockton slot demographically much firmer in the 30-min. headway category. 30 minutes being pretty damn great in terms of feasible all-day demand from Greenbush, Plymouth, and Middleboro/Buzzards Bay. But it's not going to be Red frequencies, which'll be 3 minute headways to JFK and 6 to Braintree in 2021 after the signal upgrade + car procurement projects are complete.
And even if you could tweak those RER schedules to draw close to par, it's never going to be 6 mins. with a one-seat to Kendall, Harvard, MGH, and all the other big destinations inbound of JFK. That simply can't be done on any Purple Line routing current or future, and that is the be-all/end-all for (substantial!) Quincy/Braintree transit demand.
