One question i can't tell. Does the Fairmount line (future indigo) go all the way to 128 amtrak? it comes close. If you don't extend the orange line from forest hills to 128 at this point, does it make more sense (financial and engineering ease) to make the indigo (relatively) rapid transit from 128 to SS?
Fairmount junctions with the NEC right about here at Horne St. Stoughton trains make midday deadhead moves back to Readville yard through here because there's no layover yard at Stoughton.
The NEC cannot go >4 tracks through the Neponset reservation because of the wetlands. There's a pinch point where the embankment is surrounded on all sides by water. You can do a turnout to extra 128 platforms right about here where that signal box is located. The 128 overpass is wide enough to expand the station to double its current size. But you can't make it rapid transit without busting the NEC down to 2 tracks permanently. And it's not only planned for 3 in the very near future, but will probably need all 4 soon enough. And then Fairmount's too constrained by property lines north of Blue Hill Ave. to lay any rapid transit lines, plus it can't be converted outright to rapid transit because that's the Southie port freight access.
Best you're going to do is bring the Red Line to Mattapan in place of the trolley, bridge the Mattapan-Fairmount ROW gap with a tunnel boring machine here, and go 2 RR + 2 rapid transit tracks to Readville south of Cummins where there is ample space. But then your only choice for going further is Dedham Ctr. because both the NEC and Franklin shoot out to 128 on unexpandable embankments surrounded by swamp and water.
