Equilibria
- May 6, 2007
I believe (not sure) that what they're doing here is pulling down the facade, rehab/replacing the materials off-site, and replacing the steel supports. Essentially, they're taking down the skin and everything that connected it to the inner skeleton, leaving us with just the skeleton until they put new connecting steel up.
I agree that it looks like demolition, but I don't think that's what's happening here.
http://www.bostonplans.org/getattachment/52bbacb9-a4b8-4b64-a4c0-0e59e538c184, P.13Over time, areas of the façade in various locations have deteriorated and will require extensive repairs and replacement of those façade locations to protect the interior and the integrity of the building. More specifically, the condition of the exterior cladding materials on the Little Building are integrally connected to the building’s steel frame.
Steel expansion caused by surface corrosion due to water infiltration through the mortar joints has resulted in cracking, displacement and loss in the surrounding cast stone, cast iron and brick. It is anticipated that new replacement cast material will be required from level 3 up-to and including the parapet. The cast stone below level 3 will be restored in place. The amount of replacement of existing steel supports remains unknown until the construction of the building envelope is underway.
