- Oct 14, 2009
I got some photos from directly above yesterday. I’m sure some of you will enjoy these.
At first look I was thinking is that where the core is going to rise?… but then I remembered that this tower is going to be pretty unique in that the core does not start from ground level but will actually be above the arches over the platforms.
If Im not mistaken the core is going to start above these peoples heads and then be tied into the ground through each of the “legs” here.
Zooming in on the image of the steel structure it looks like theres shorter diagonal bracing just above the open atrium running around the entire perimeter of the structure tying the perimeter columns together and then theres also a few very long diagonal braces that then tie the outer steel beams (which are tied together) directly to the columns of the atrium.
