themissinglink
- Jan 13, 2018
I've decided to create this new thread since there isn't a collective thread for unbuilt highways/roadways in Massachusetts, only one for unbuilt roads around metro Boston. If this thread belongs elsewhere on the forum, it would be much appreciated if the thread was moved to its rightful place by the mods.
I wanted to share these newspaper clippings that I discovered about the formerly proposed "Pittsfield Bypass", the controversial limited-access roadway which had been long-planned in the Pittsfield area. There were several different variations of the proposal; some included a connection with the existing Lenox Bypass while others did not. An alignment through the western part of the city was clearly favored over an eastern alignment, although neither was deemed acceptable (many houses would have been razed if the plan went forward) and the project was perpetually put on hold due to community opposition. The only part of the bypass to actually be constructed is Dan Fox Drive in Pittsfield, which was built in 1988 to provide a connection between US 7 and Pittsfield Municipal Airport.
I've heard that the bypass would have been designated as I-390 if the proposal was fully built out as a 4-lane expressway and connected to the Lenox bypass (which would have assumedly been upgraded to Interstate Highway standards and given a direct connection to the Pike). However I have not (yet) found a source to corroborate this rumor, so take the supposed I-390 designation with a grain of salt.
This snippet of the 1977 Pittsfield city report appeared in The Berkshire Eagle in June 1978, when the eastern alignment of the bypass was still in active consideration.
This snippet from The Berkshire Eagle dated October 6, 1978 includes a precise description of the western alignment in Pittsfield, accompanied by two conceptual depictions of interchanges.
This article appeared in The North Adams Transcript on October 27, 1987. It includes a map of the Pittsfield Bypass which notably lacks a connection with the Lenox Bypass, instead terminating at an interchange with US 7 in Pittsfield (at the current location of the Dan Fox Drive/US 7 intersection).
This article in The Berkshire Eagle from October 30, 1994 discusses the history of the bypass plan, due to a nonbinding ballot referendum about the bypass. A map of several alternatives for a connection between the Mass Pike and the Lenox Bypass is shown; the connector would have terminated at US 7 or US 20 at the northern end and the Pike or MA 102 at the southern end.
