- Oct 14, 2009
Finally the crown has started to be clad! Cant wait to see how it turns out.
DZ, in the first pic it seems Millenium is a good 20 ft taller. Wiki says that it has a height of 698 to pinnacle, so isnt MILLENIUM actiually taller then? I am confused to what is the pinnacle anyway on the Millenium, with the angled crown.
MT is in front of Winthrop from this angle, which is close enough to the city where that still matters more. It's 1-2 blocks closer. It's also about 5' higher in elevation. The 698' is to the top of the lightning rod. The slanted roof tops at 685'.
Regardless of height, from grade, or actual blah. MT from almost all angles sub the 93S quadrant, LOOKS not just taller but considerably from many.
IMG_2436 by David Z, on Flickr
IMG_9812 by Bos Beeline, on Flickr
IMG_9814 by Bos Beeline, on Flickr
IMG_9898 by Bos Beeline, on Flickr
IMG_9933 by Bos Beeline, on Flickr
IMG_9934 by Bos Beeline, on Flickr
IMG_9656 by Bos Beeline, on Flickr
IMG_9666 by Bos Beeline, on Flickr
IMG_9664 by Bos Beeline, on Flickr
IMG_9663 by Bos Beeline, on Flickr
IMG_9680 by Bos Beeline, on Flickr
IMG_9683 by Bos Beeline, on Flickr
IMG_9684 by Bos Beeline, on Flickr
IMG_9722 by Bos Beeline, on Flickr
IMG_9717 by Bos Beeline, on Flickr
IMG_9702 by Bos Beeline, on Flickr
(Slightly out of focus)They have some massive 40x6 panes of glass in at the entry on the Winthrop Square side.
IMG_0188 by Bos Beeline, on FlickrThe top is looking busier/sloppier than expected. It could just be the lighting, but you can't see all the individual windows in the renders like you see above. Maybe it will also look better once it's done.
The in-crown grooves better be fucking illuminated at night, tell you what
