I don't know, because I think the Urban Ring study site the state set up has been taken down. But it did have ridership studies, at least through the BRT Phase II. It was mega. There's definitely justification for a rail line through there. Frankly I think that should be the first leg done, as light rail. The Grand Junction obviously can't be done until there's some replacement (N-S Link or new connecting track) for the northside/southside equipment shuttle, but you can definitely do a Green Line branch off Lechmere. The new
carhouse location for GLX traces out the ROW on trajectory to Sullivan. To make it a revenue track you would:
Phase I (really easy...this really should be a future tack-on to GLX that they do at same time as a Union-Porter extension)
1. Reconfigure yard switches and whatnot so it's a thru track.
2. NOT do something stupid like making the flyover ramps to the yard leads single-track or something (the drawings are vague about that, so reason to be nervous).
3. Do a very quick duck-under tunnel under the freight wye. Duck-unders aren't hard with trolleys because they can handle steep grades (see the B/C/E inclines).
4. Plunk new platforms on the double-track freight storage tracks next to Sullivan.
Phase II
5. Figure out where you're getting across the Mystic, and widen either the Eastern Route bridge or the Orange/Haverhill bridge. They want to hit both Assembly and Wellington. I think that's going to be too expensive, too tight a fit, and too hard to EIS around the Mystic wetlands. Parallel-spanning the Eastern Route bridge is a lot more straightforward. The old draw span that existed there until the 1980's still has preserved approaches on the south side of the current span. What you could do it build the parallel span, relocate commuter rail onto that, and put the trolleys on the existing span (see next bullet on why they need to stay on north side of the RR tracks)
6. Stay on the north side of the Eastern Route tracks (Everett terminal freight tracks are on the south side), stop at Gateway Ctr. Also provides Saugus Branch accessibility for the trail and (maybe, but I doubt it) some spur 50 years from now.
7. Chelsea station, displacing the CR station. That's also the only grade crossing that's near-impossible to eliminate, so that's why I'm skeptical this could ever be heavy rail.
8. Duck-under or flyover to the abandoned wye. Station at Griffin Way. Make this the turnback for now.
Phase III
9. Merge onto Chelsea St. bridge in mixed traffic.
10. Peel off onto the Haul Road ROW. Haul Road shifted over so both can fit, narrow bridges like Bennington widened to their former width.
11. Continue on to Airport station on the currently trailed portion of the ROW. It's a block-wide linear park, so trail doesn't go away.
Phase IV
12. Logan Terminals El. Can do it hugging the second level of the parking garage the next time 30 years when Logan's up for a total renovation like it got in the early 90's. Buffer exists for
ROW next to the Pike. Make it a dual busway with rail in pavement so both light rail and Silver Line from SS can share it grade-separated. Sort of a Terminal Transitway.
I mean, this is like 30 years total so it's not as awe-inspiringly complicated as it would look as a monolith. Figure you're picking off 1 phase per decade, with II and III following each other in quicker succession like the GLX Phase I to Medford Hillside and Phase II to Route 16.
