Equilibria
- May 6, 2007
This is not feasible. Making it rails instead of roads doesn't make the Robert Moses mentality of blowing up anything hell-be-damned to get multiple straight-line paths from everywhere to everywhere any more feasible. On the scale you're proposing it's caustically disruptive and unsustainable. Move on from this mapmaking perfectionism; it's divorced from any plausibility.
F-Line, how do you define an "existing" transit corridor? I see your point that the projects most worth doing are the low-hanging fruit on existing facilities (and your analyses of those prospects have been excellent), but there ARE markets in Boston underserved by transit, and there IS a conceptual need for new facilities. Are you simply in favor of using existing ROW instead of blazing new trails?
Also, the big difference between the Robert Moses (or William Callahan, for Boston) mentality for roads and any build-it-big mentality for transit is that you can drive to highways from anywhere without leaving your seat. Having redundant highways, even 5 or 10 miles apart, is problematic since the same people could drive to either road. Transit, particularly in the periphery, has a much smaller service area and generally speaking can only serve people either originating or arriving within walking distance of a station (unless you want to transfer on both ends). Since different lines have different destinations and purposes, that does allow for some redundancy. The 3 GL brances in Brookline are all within a half a mile at Cleveland Circle, for instance, but they all do fairly well in ridership.
My issue with your cost logic - that you should always take the cheapest and easiest option - is that it's never cheaper to build something than it is right now. Construction and materials prices only go up, even faster than inflation. If BERy had built the Esplanade subway or the Red Line extension to Lexington or any of the other projects they never got to do, those would be "existing infrastructure" now and for a much lower cost than they could ever be built today. If we go with your plan and build the Silver Line under the NEC, where it misses serving any of Downtown but South Station, I worry that it will always be something we didn't do because it was hard, and we ended up with a sub-standard system, the same way we already have with the Orange Line and even the GLX.
I'm all for transit extensions favoring existing ROW, that just makes sense, and I love the idea of picking low-hanging fruit like signal renovations and multiple units. I think that's the immediate future of transit improvements in Boston if there is one at all. But for larger projects, new lines, routings, etc, we should be like Daniel Burnham and make no small plans. If we can only do it on paper, at least we can do it right.
