hipster_garbage
New member
- Mar 6, 2017
For someone like me it doesn't make a difference. I'll ride up it at 15 mph and not care about how drenched in sweat I get because at either end I'm taking a shower. But if you're using it to run errands or just generally get around I can see how the slope could be annoying. I think a majority of people expect off street bike paths to be relatively flat. The community path undulates up and down a ton whereas paths like the Minuteman, Mass Central, or Bruce Freeman are essentially pan flat for their entire lengths. The bridge itself to a seasoned rider is just a small bump but to a lot of people it probably seems huge at first, since a lot of people will go out of their way to avoid hills at all costs.Is this such a bad thing? The burn means you're not only getting to where you need to go but getting some *actual* exercise doing so. I've biked the bridge and a person of just average fitness at any age should be able to do it easily at their own speed. And if you do it enough times it'll only get easier.
But like you said, do it enough times and it'll only get easier.
