with something as complicated as your proposed reconfiguration the results of detailed multi-node multi-mode dynamic simulations might be that things got substantially worse rather than slightly better
This.
The immediate topic is the bowker, but the scope of the issue is access to points south of the pike from the catchment basin served by storrow - thats everything from the Allston tolls to the Tip tunnel, and it ultimately includes Cambridge access via the bridges and the E-W through flow on storrow and the pike as well.
Ideally then (or in a technocratic utopia, at least), the Bowker studies would be merged with the beacon yards do-over and the storrow tunnel euthanasia planning. And we'd throw in pike air rights and river crossings as well. That way you could build a plan that would deliver a distributed load to enable downgrading storrow and the bowker, based on a subset of the following:
- Build new 'air rights avenues' as pike dis/tributaries both E and W of the Pru (borrowing the fourth lane from the pike and widening the bay village cut for ramp leads where appropriate - and with the promise of filling in the fabric above)
- Connect longwood with west-side pike and SFR via audubon circle, park ave and cottage farm
- Streamline the cottage farm / magazine beach interface, to get better leverage from Mem Drive for access to cambridge and kendall (and an alternate route to 93N and the Tobin)
- un-fuck the gilmore bridge (again, tobin from the W via mem)
- Integrate beacon and boylston into E-W load balancing
- Better-integrate cambridge st (beacon hill) and charles st into downtown access, to take pressure off levrett cir
- while we're at it, reduce the Cambridge St. Allston crush by adding ramps to Nonantum and the Bergin Parkway at NB / Boston Landing (and un-fuck the circle of death in the process)
- also, umm, transit and DMUs
In other words, the issue is the network, not the node, and so the solution has to come at the network level. I recognize that the strategic is only meaningful in dialogue with the tactical, and that a finite scope is always a prerequisite for actionability, but what will it take to get some comprehensive planning done here?
Our planning and building systems are built for focus - where's the synthesis? For that matter, where's the ArchB synthesis conversation? Anyone up for Crazy Regional Mobility and Prosperity Pitches?
