- Jan 22, 2012
Winston or F-Line?
Here's what F-Line has said in the past on CBTC for the Green Line [emphasis mine]:
The basic design would be CBTC. Which can either have moving blocks or fixed blocks. Since the blocks are mostly software-based and virtual, it can be whatever you program it to be. Moving blocks probably are not going to work in the Central Subway, so they would have to implement it with fixed blocks more or less the same as the current setup. And surgically fine-tuned to not decay headways under computer guidance vs. line-of-sight/human judgement. That's hard. Not impossible, but really really hard. And they have to get it right on the first try, so they can't proceed with haste.
IF such a setup can be designed it wouldn't increase throughput, but would bring all the other compelling advantages advantages of CBTC: safer operation with auto stop enforcement, vastly less track-mounted hardware to maintain, far less reliance on human dispatching. But, again, Central Subway capacity isn't the issue so much as unpredictability of branch schedules causing clogs where they intermix. So half the battle of making it run smoother is getting the branches all reliably on-schedule. Fix the surface clogs on the B and C first. Then a more conventional CBTC setup on the D and GLX to manage those headways. At a purely traffic management level the Central Subway can thrive as-is if the pen-and-pad guesswork were reduced to just the Kenmore-North Station stretch with more accurate branch arrival times. After all, it handled many more branches than this a half-century ago and lots of 3-car operation back then too. The main argument for CBTC downtown is purely safety: preventing operator-error incidents like the Gov't Ctr. crash. With secondary considerations for lowering maintenance burden and preventing crippling signal downtime like there was for months after the '96 flood shorted out everything from Kenmore to Copley. All of that's worthwhile enough to keep plugging away at the studies for due diligence.
It's the fucking-with-headways thing. And every one tweak having 3 unintended consequences. This is so difficult...and so difficult to do as open-heart surgery during active service...that you can't assume there will be any improvements whatsoever. The block locations may shift slightly, but it is far-fetched to see how this will result in headway enhancement. It may take 10 years to design something that even meets the do-no-harm standard, and there will be compromises. It is entirely possible that a 'tolerable' level of headway limitations will prove acceptable for installing CBTC if counteracted with 4-car trains and other enhancements compensating for a new headway cap. Enhancement is not the reason they'd be considering CBTC on the Central Subway. Safety, safety, safety. Because there are questions about how safe an operation line-of-sight is with that kind of density and such hugely heavy modern LRV's.
It's not a magic bullet. It's not intended to be one. And it doesn't do the same thing here that it would do on Red/Blue/Orange or D/GLX. Where they have to thread the needle is finding the do-no-harm compromise point, or as close as they can get to it. You are not getting throughput enhancements. The only way to do that is by biting the bullet and constructing parallel subway trunks: Huntington to Brookline Village, South End-Back Bay-Huntington, and Grand Junction LRT between Lechmere and a BU Bridge subway extension. Route the traffic on different circuits for exponential capacity increases. No Jetsons shit is going to do that on signals alone in a 115-year-old continuously operating trolley subway.
You can, however, make the whole thing run properly by getting trains into the subway on-time. That's a known-known, because that's how it all worked when there were more branches to juggle. That's what the current means of dispatching is predicated on. Fixing the B bottlenecks, streamlining the C, and re-signaling the D and GLX do that job. Do it well enough that you can still fit in other extensions. That's where the crux of the problem is. That's where the solution has to come from. Downtown doesn't make the branches operate better. The branches make downtown operate better.
