Commuter Rail Stations in Newton
BostonUrbEx
If you need to go inbound from Newton to Boston, and you miss the last one at 2pm, you can wait 11 hours for the 1am the next day. That's insane.
The problem is that there's platforms on one side of the tracks only, forcing outbound trains to use the wrong track during PM hours. Now, I'm looking at Newtonville and West Newton and I can EASILY see another platform being added on the outbound side at each station. Why has this not been done yet? These stations see fairly decent traffic, don't they? What is up with this...
They were rebuilt that way in 1965 at discretion of the Turnpike Authority when it relocated the tracks to build the Pike extension. Passenger traffic was withering away by that point and Boston & Albany RR didn't really give a crap about its only commuter rail line (Worcester and Providence/Stoughton were the only lines the T wasn't subsidizing at all in the early days), so they went with the cheapest possible build on those 3 stops.
All 3 are totally non-ADA, so they have to get full rebuilds soon regardless. And the single-track running here for outbound trains using these stops is the single biggest post-Beacon Park bottleneck remaining on the line. Plus they're absolutely disgusting with shelters crumbling to bits. So it's a fait accompli that any rebuilt stations are going to have 2 platforms and will get full-highs (no more wide-clearance freights = no restrictions on level boarding). Plus ramps and/or elevators to the street for ADA.
When is the issue of course. None of them are scheduled yet. But it'll have to be within next 5-7 years to increase service levels like they say because that single-track bottleneck gets worse with the increased traffic. And the ADA situation on this line is a joke. All 7 stations between Yawkey and West Natick are non-compliant, the longest bloc of inaccessible stations on the system. This line is highest priority by far on the whole commuter rail for station repair and renewal.
West Newton and Newtonville are the most unpleasant possible places to wait for a train. I don't know how much they can be improved given the roaring Turnpike next to them.
If they removed the diagonal parking along Washington Street they could probably actually take a 10-15 feet of Washington for two platforms and an express track.
Doesn't this mean that MBTA cannot perform any platform (or Station) upgrades or modifications (such as fix a cumbling shelter) without making additional modifications for ADA compliance?
No, they can do repairs. ADA isn't so nihilist a law that it forces a situation where you'd either have to pony up or defer maintenance so long that accessibility gets worse. The only thing those 3 appear to be scheduled for on the FY2012-2016 cap improvements document is lighting upgrades and "design" (unfunded) for Auburndale ADA. Whatever that means; I don't see any construction schedule attached to that line item.
They're going to have to step it up bigtime. They are in definite trouble with the law if they let 7 consecutive stations--a couple of them Top 10 in boardings among non-compliant CR stops--stay inaccessible much longer. Especially on a line with Worcester's ridership where the short-term service plan doubles the number of trains. This is a situation where broke-or-not-broke they're going to have to find some money and seek some grants. I think it'll be available because there's a lot of little junk like this they have to do with the inner Worcester Line to make it run better, but station ADA rebuilds and the second platforms on these 3 are not luxury items they can defer beyond the 5-year range due to debt service. This comes under the deferred maintenance umbrella the D'Alessandro Report reamed them for.
They have a viable excuse in Beacon Park for waiting this long. Until CSX relocates west the stations are under a wide freight clearance exemption from high platforms. This is why the stops on the outer half of the line, which all opened within +/- 2 years of 2000 a full decade after ADA was passed, were built with mini-highs instead of full-highs. Same exemption is in effect for all of the Lowell Line, Haverhill Line north of Wilmington and all Downeaster stops, Fitchburg Line Ayer and points west, Franklin Line between Walpole and Readville, the NEC between Mansfield and Attleboro, and Foxboro on the Framingham Secondary. Only full-highs allowed are at stations that have passing tracks or where passenger trains switch to the opposite track and stop at a single platform only. e.g. the highs at Anderson/Woburn, Lawrence, Worcester and Lowell terminals, and the designs for single-platform terminals Wachusett and Plaistow. Those Worcester Line mini-highs have spring-loaded platform edges that the oversize freights can push aside, and that's not possible to do with a full-high that's 8 cars long and/or on a curve. If they wait until Beacon Park's gone that exemption gets lifted and they can do full-highs on all 7 of those non-ADA stops and raise West Natick (Framingham conceivably as well if CSX built a passing track on all that space behind the station). The once-daily produce train to Everett Terminal that'll remain after Beacon Park closes doesn't use any wide-load cars.
Tallish wall. Maybe not the size/strength of a typical highway sound barrier, but a whole lot better than the rotting wood Home Depot fence currently at Newtonville. Can be done without too much expense. It just needs to be tall enough and solid enough to block the visual/aural terror of cars zooming past and all the dirt and debris that gets chucked up by the Pike traffic which the current wood fence doesn't do nearly enough to block.
Plus less disgusting shelters. This is like waiting for a train inside of a chicken coop. If those aren't the 3 worst stations on the entire system, they're most definitely in the Bottom 5.
No kidding. Waiting forever while traffic flies past you Boston-ward is not exactly the most encouraging experience for someone on the fence about a transit-based commute. It also seriously minimizes the amount of TOD that can take advantage of a nearby station.
This is going to be a perpetual problem for Sunbelt cities that have expanded transit lines along highway ROWs.
Correct way to plan ADA:
Yawkey, and thus the entire Worcester line, needs to be shut down in 2013 so that they can move the tracks and get a center platform installed.
The Newtons need a center platform (only need one elevator).
The correct thing to do is get it all done at once, as to disrupt riders for as little time as possible.
Wht MBTA will probably do: Schedule the projects sequentially.
Moving a couple hundred feet of tracks can be done overnight one track at a time. That doesn't require any service disruption. They can do the outbound-side tracks at all 3 stations in 3 weekends if they prepped the retaining walls before then. They'd have to demolish the platforms to move the inbound track, but it's not like razing a wood chicken-coop shelter and jackhammering up a stretch of narrow crumbling asphalt is a big job. They can probably obliterate each station over the span of a workweek with regular service speeding by on the outbound track.
Then burn rubber constructing the new platforms so it's doable in something like 9 months. The high platforms they use most places have prefab supports underneath, so aren't exactly involved jobs. Erect some temporary stairs to reopen them quick on the bare platform while they finish the ADA ramps and put in the new shelters, etc. But stick to the prefab platform structures like the Old Colony line stations and DO NOT EVEN THINK ABOUT BUILDING another wasteful station building monstrosity like new Yawkey. It's Newton, FFS.
The other platforms on the line are straight raisings. Do 'em one at a time, and do the necessary overhead stairs to eliminate ped grade crossings at the stations that need 'em. Some of them like the 3 Wellesley stations and Natick have historic station houses or other access features that'll keep them permanently as side platforms, unlike the Newton trio. That's no big deal; plenty of those get retrofitted for full-highs all the time. The key is not going completely insane with overdesign. Not having the BRA sticking its fingerprints all over like the Meninomonument at Yawkey helps too. Historical preservation on the ones with old station buildings also helps keep changes muted and avoids the kind of design creep and local yokel games that've driven up the price on total blow-up/rebuilds like South Acton and Littleton.
