I know! I can recall the triangles too. Please God, no more iterations!! Just replace all the dead trees with a consistent species. I'm sorry that some great ones, like lindens, have fallen out of favor. I really dislike the plane tree species.Again?
I can still remember when it was a triangle!
There is a lot more than trees that need at least major repairs. The pavers are all cracked. The fountain no longer works (I am pretty sure). Usage has changed with the weekly farmer's market along St. James. If you are going to pull up most of the infrastructure, maybe it is OK to rethink it a bit?I know! I can recall the triangles too. Please God, no more iterations!! Just replace all the dead trees with a consistent species. I'm sorry that some great ones, like lindens, have fallen out of favor. I really dislike the plane tree species.
Wish I'd remembered to comment. I thought it'd be really cool to create a grove of cherry blossom trees on Copley.
Japan has gifted cherry trees to Boston many times apparently. And believe it or not, the Esplanade is considered one of the best places in the country to see cherry blossoms. See https://www.japansocietyboston.org/sakura/eng, https://discovery.cathaypacific.com/7-us-cities-embrace-cherry-blossom-season/ and http://archive.boston.com/business/articles/2003/12/19/blossoming_dispute/Washington dc had a few thousand cherry blossoms donated from japan a long time ago maybe we could get some from japan as well to have some type of story with them and also a connection to another city that will last hundreds of years. This could really be something awesome. Itd be a great reason to go to copley square once a year! Maybe put some on the greenway as well?
Jeff, I get it. The trouble is that those who rethink such important areas are too often looking for novelty rather than creating public spaces that have legitimate limited use. The irony is I predicted what would happen when Copley was redone this last time. First, I knew that using slate in the paving design would be a disaster in the winter, when it would shatter with the ice and create tripping hazards. I later witnessed the painstaking work to pull up and reset select stone. Second, I knew that the plane trees would not succeed ultimately, due to their habit and the way their root systems were tramped upon by pedestrians. Finally disease took out a lot of them and years of growth and shade were sabotaged. Third, I felt that the area to the left of the church would always be a no-man's land and it has been mostly a wind-swept area for the homeless. Fourth, I knew that the lawn would be horrible to keep up with if used regularly. That said there should have been benches facing the lawn and allowing for much more interaction with the grass...after all, if it's going to ruined let's enjoy it in the meantime. Fifth, as with nearly every fountain installed in Boston in the last 50 years, this one has also apparently failed....what's to stop the new one from also failing, unless it's 'adopted' by a corporation for ongoing maintenance. Sixth, there need to be more benches arranged for more private sitting, without having to face unpleasant characters strung out on substances (yes I'm a bit of snob when it comes to personal space). Seventh, the memorial to the Ghibran got lost in it's location. The statue of Copley, which I really like, is also lost in the attempt to be "accessible" on a short pedestal. It needs an explanatory plaque. And yes, the farmers' market needs space that is twice as wide. The sidewalk is impassable when it's there. I could go on. It's as if they design these things without asking normal people what they think or how they'll use it, etc. The only bright spot has been the turtle and hare sculpture which entertains kids. So yes, spend a few more million $$$ and redo it once again. Public squares that keep changing do not have the appropriate impact. They become transient features wherein people cannot make lasting memories...novelty wears thin very quickly, IMHO. Imagine revamping Piazza Navona every few decades....it makes no sense. Proper design and maintenance are the keys. I sadly witnessed the Square go downhill and get really dumpy the last couple of decades. There's no excuse for it.There is a lot more than trees that need at least major repairs. The pavers are all cracked. The fountain no longer works (I am pretty sure). Usage has changed with the weekly farmer's market along St. James. If you are going to pull up most of the infrastructure, maybe it is OK to rethink it a bit?
All excellent points. We try to make these prominent spaces do to much, and in the end they are ill designed for all the too many purposes.Jeff, I get it. The trouble is that those who rethink such important areas are too often looking for novelty rather than creating public spaces that have legitimate limited use. The irony is I predicted what would happen when Copley was redone this last time. First, I knew that using slate in the paving design would be a disaster in the winter, when it would shatter with the ice and create tripping hazards. I later witnessed the painstaking work to pull up and reset select stone. Second, I knew that the plane trees would not succeed ultimately, due to their habit and the way their root systems were tramped upon by pedestrians. Finally disease took out a lot of them and years of growth and shade were sabotaged. Third, I felt that the area to the left of the church would always be a no-man's land and it has been mostly a wind-swept area for the homeless. Fourth, I knew that the lawn would be horrible to keep up with if used regularly. That said there should have been benches facing the lawn and allowing for much more interaction with the grass...after all, if it's going to ruined let's enjoy it in the meantime. Fifth, as with nearly every fountain installed in Boston in the last 50 years, this one has also apparently failed....what's to stop the new one from also failing, unless it's 'adopted' by a corporation for ongoing maintenance. Sixth, there need to be more benches arranged for more private sitting, without having to face unpleasant characters strung out on substances (yes I'm a bit of snob when it comes to personal space). Seventh, the memorial to the Ghibran got lost in it's location. The statue of Copley, which I really like, is also lost in the attempt to be "accessible" on a short pedestal. It needs an explanatory plaque. And yes, the farmers' market needs space that is twice as wide. The sidewalk is impassable when it's there. I could go on. It's as if they design these things without asking normal people what they think or how they'll use it, etc. The only bright spot has been the turtle and hare sculpture which entertains kids. So yes, spend a few more million $$$ and redo it once again. Public squares that keep changing do not have the appropriate impact. They become transient features wherein people cannot make lasting memories...novelty wears thin very quickly, IMHO. Imagine revamping Piazza Navona every few decades....it makes no sense. Proper design and maintenance are the keys. I sadly witnessed the Square go downhill and get really dumpy the last couple of decades. There's no excuse for it.
