Yeah - Grove Hall would make a lot of sense. I was just hoping that maybe with a full 4 track build + regional rail/all emu service it might be possible (along opening up slots by taking Needham off the NEC with Orange/Green replacements), since its on an existing row, and Rozzie Square is still over .5 miles away, and it would probably spur development on that portion of Hyde Park Ave/American Legion.
Unfortunately the NEC is the one place where quadding + EMU'ing does not open up realistic infill opportunities, because of the need for express vs. local overtakes to make hay on building up speed between the Back Bay-Ruggles slow zone and Route 128. As is, Forest Hills can't be functionally added to any non-Needham schedules because the island platform there is squished to one side and would require crossing over the express tracks to the tune of numerous Amtrak conflicts. And the Hyde Park quad-track redesign simply replicates FH's squished island layout from lack of room on the Business St. side (where Track 4 ultimately goes). It won't be able to have its current 2-side platform layout re-created with 4 tracks.
That's a deadly pickle for a Mt. Hope Redux stop. It can't be done as a 2-side platform even if room exists for it because both adjacent stops are going to be squished; it would induce even more crossover moves that can't be done with Amtrak traffic modeling. You'd thus have to make the infill platform a matching squished configuration to FH/HP so trains stay on the same tracks between intracity stops, and that ends up severely limiting which line schedules are capable of reaching the "squished" side. Consider that Forge Park schedules (the easiest of all for running on the squished side) are likely to get throttled-down on the NEC over time and throttled-up over the Fairmount Line for congestion mitigation, with an endgame future of likely 85-100% of Franklin schedules going via Fairmount. Foxboro--both the limited-trial set to begin and the full-blown proposal--are already slated to be captive to Fairmount from Day 1 to lower the Franklin main's impact on NEC congestion. Stoughton, as previously noted, is going to be forced to dump all intracity stops between Back Bay and 128 permanently for the sake of keeping schedule if it is ever extended to Taunton or beyond, and thus isn't a safe bet for pinning a stable lifetime schedule anchor on an expanded infill slate. Then consider that super-extended RI runs on Providence are going to skip the intracity stops anyway, and so you're left with basically the same underwhelming selection of Providence local-only schedules that leaves service levels at HP permanently half-cocked. With whatever increases come from Regional Rail-ification still falling several degrees short of what's possible at all the other Zone 1A intracity stops on other lines. It may not be completely broken transit...but it's broken-ish and of limited overall upside given all other mouths the NEC has to feed and how critical track+platform layout ends up being for feeding those mouths.
Doesn't get much better in an NSRL universe either as length of schedule will determine slotting on the "squished" tracks vs. the express tracks. It's more slots, sure...but with all of the intracity stops getting exponentially more slots the NEC intermediates from FH to HP are still proportionately MUCH poorer-off on frequencies than the Fairmount corridor or comparable Allston-Newton stops on the Worcester Line.
Writing's on the wall because if the "squished" layout is the only thing they can physically conjure there's no practical future for FH & HP stations on the NEC, and likewise no practical future for any new intermediates that span those two stops as they'd be locked into the same layout. So best move is to crank up Fairmount frequencies so HP can be outright retired by the time NEC Track 4 is necessary, and bring the Orange Line to Rozzie Sq. as a +1 or outright displacement of Needham CR. Historically, Mt. Hope ridership crashed at the turn of the century when streetcars debuted on today's 32 bus route. 20th century ridership was so very poor it's a historical mystery that it even lasted until '79 as a flag stop; it was either one of those Plimptonville/Hastings rumps that multiple generations of RR management simply forgot to prune and/or there were a couple long-dead neighbors with political influence being a stick in the mud about keeping it all that time. But a perma-solve for the bus route duplication & over-congestion on Lower Washington via truncating some routes at a new Rozzie Orange Line transfer will most definitely help the Mt. Hope Redux catchment as the 14 and 30 both cross @ Cummins & HP Ave. along with the 32. There's probably more absolute transit frequencies to be had via OL-Rozzie and revamped bus terminals than you could ever achieve via Regional Rail with only that crippled "squished" platform layout available to limited schedules.
Only intracity NEC infill that doesn't suffer from that killer "squished" malady is re-use of the mothballed Readville NEC platforms, which have such generous slack space they can remain full-sized 2-side platforms when Track 4 comes back. If HP station gets abandoned in favor of service consolidation to Fairmount station, then there won't be any need for NEC locals on the outer tracks to do any crossing over of the express tracks anywhere outbound of Ruggles, making reanimated Readville side platforms a fully feasible service add at no congestion penalty. Obviously the NEC + Franklin platforms make for useful enough superstation transfer if the Fairmount side sees supersized frequencies, so that's one to shoot for even if today's Readville pales in comparison to Cleary Sq./Fairmount as a neighborhood transit center. Might even be possible to go >4 with the track layout if the whole works were shifted a couple hundred feet north re-centered around the Milton St. overpass, as there's a lot of derelict old platform space stretching far north of the current 1987 facility. Note also: the Fairmount platform at Readville will be moving from its current single-side location on the NEC overpass to a new site across from Milton St. in order to fit the double-track island platform that'll fully support true "Indigo" frequencies. So there'll ultimately be supportable logic in pursuing a reciprocal re-centering of the NEC- and Franklin-side Readville platform entrances around Milton St. to keep the whole superstation's sprawl as compact as possible.
