This is a terminology mix-up.
Back to the mix-up:
The “surface GL branches” are not rapid transit nor do they function as rapid transit (except arguably, the GLX, but that doesn’t appear to be what you’re referring to). Rather, it’s light rail, with only one (the Green Line E branch) running regular service on an undivided street. One could use the term streetcar/tram when referring to this section.
So, like I said, there are many words that can be used to describe the difference between streetcars/trams and rapid transit (also known as metro or heavy rail): grade separation, speed, capacity, dedicated right-of-way, infrastructure, distance between stations, vehicle size, network scale.
I hope this helps and I know this terminology can be tricky, nuanced, and have overlap.
I appreciate that you are trying to be helpful here. I do want to say, 1) I significantly disagree with your interpretation of the term "rapid transit", and 2) this is just my personal opinion, but I do feel the way you've presented this sounds a bit condescending and dismissive. I am mindful that I myself often "over-explain" and probably sound condescending and dismissive as well, so I don't mean to be harsh.Ultimately you can use whatever words you want in whatever way you want. But using these terms the way they are understood both generally and by those reading this forum will help you be understood better. Over my decade of being way too active on this board I’ve often thought that having a terms and abbreviations reference page would be helpful. That’s all I was trying to help with.
If you don’t want to use these terms in the same way they are generally used and understood, it’s your prerogative and no big deal to me. You may run into more of these confusions, though. I enjoy reading your posts, nonetheless, and welcome to this forum! I hope you remain an active contributor for years to come.
Have a nice day!
But I think the term "rapid transit" is particularly vague and almost always requires additional clarification; you've suggested here that there are hard-and-fast rules about what "counts" as rapid transit, and you've used that claim to dismiss the (actually very different) point that TheRatmeister was making:
To me, this reads as a point about the "placemaking" aspects of the question, "What gets shown on the T map with the same visual language as the Red, Orange, Blue, and Green Lines?" Regardless of any broader definition of "rapid transit", the question at hand here is a very specific one about Boston's context and local ideas about what constitutes a "line". And in that context, the broader definition really doesn't matter (even if it should).One last note: What separates rapid transit lines from streetcar/tram routes? In my mind, it's one word: Frequency. Rapid transit lines should provide 10m headways or lower on an extended, cohesive corridor, rather than achieving this with merging many services onto a shorter trunk route. That's why Columbus Ave doesn't get to be a rapid transit line on this map. As you can see on the map however, rapid transit style LRT service can certainly coexist with a local streetcar service, I think BHA is an excellent example of where this makes sense.
@TheRatmeister, I think this is a very cool map! I've thought about similar things (and in fact have a draft blog post entitled "Light Rail for All"), and I like how you are trying to tease out a niche where LRT rolling stock is used for slightly lower-frequency service that would feel meaningfully different in character from, for example, the Green Line.
Some assorted thoughts:
Aqua Line: what's your thinking on your current Pleasant St alignment vs continuing with median-running on Route 20 all the way to Waltham Central Square?
GL F: I like the thought process you've used on the rest of the map, and along those lines my challenge to you would be to find an interesting way to split this route into two. For example, I've been playing around with a Park St <> MLK Blvd route complemented by a route that runs along Blue Hill Ave + Seaver St. You have some other routes on this map of similar length, like that Medford-Revere route, but I think, for example, the Medford-Revere route works because the Revere Beach Parkway and the rest of Route 16 have already taken care of pruning traffic lights and intersections, which speeds up travel. Blue Hill Ave, by contrast, looks like it has a crosswalk roughly every 1000 feet or less, while Revere Beach Parkway, by comparison, appears to run the entire 1.4 mile stretch between Winthrop Ave and Garfield Ave without a single crosswalk. (What the actual eff, jeez. I mean, it's good for your map, but jeez.)
To be clear, I agree that the entire GL F corridor merits the kind of service you're describing, I just think it shouldn't be a single service.
2: I like the idea of a branching Mass Ave service! Especially one that still serves Nubian! You could also instead/additionally run a Kendall-Mass Ave-Ruggles-Nubian service along the route you've shown here, which would fill a gap @Teban54 and I have been chatting about.
16: You might consider rerouting this directly through Franklin Park. Yes, it would have to be in mixed traffic, but it would be much more direct, and it would be an absolutely gorgeous ride. (It could be worth trying to estimate the speeds on Morton + Blue Hill under your current alignment and compare them to possible speeds through the park itself -- my wild guess is that Morton + Blue Hill would not be fast enough to offset the longer distance.)
I'd urge you to reconsider Hyde Park Ave and the 77's corridor (Mass Ave to Arlington). The 32 along Hyde Park Ave is a Top 10 ridership route, with ridership figures in the ballpark of the Green Line C Branch, and historically ran at frequencies equal or better than the Braintree Branch every day until 10pm, except Sundays. The Better Bus Profile noted that overcrowding was a significant problem on the route. To me, that points to the rare situation where mixed street-running light rail can still be the right move, since LRT vehicles are always going to beat diesel buses on capacity.Here's ones I wanted to include or considering including but opted not to:
- Ashmont-JFK via Gallivan and Morrissey: I felt like it paralleled the RL too much and didn't serve a huge purpose
- American Legion Hwy: Mainly strip malls and big box stores, not a great route without major redevelopment
- Hyde Park Ave: Mostly too narrow, also generally parallels the CR, why not just improve that?
- Washington St (Brighton): Again, too narrow. If all the street parking is removed then maybe it's possible but good luck with that. That one can go in the god-mode thread for now.
- Mass Ave north of Harvard Sq: Again felt like it paralleled the RL too much to make sense
- Blue Hills Pkwy south of Mattapan: If Milton really wants it they can pay for it, but we all no that's a no and a no.
- Talbot Ave: Again, slightly too narrow, would require removing all the street parking
- The 66: Even with all the street parking removed it would still likely require mixed traffic running, and lots of the street parking removal would need to happen in Brookline, see previous post in this thread.
The 77 is not quite the behemoth that the 32 is, but it still is a high ridership route running along a relatively wide street. I can understand some hesitance about paralleling the Red Line all the way to Harvard (although note that a large fraction of riders still go all the way to Harvard, suggesting that it is their final destination, rather than transferring to the Red at the earlier opportunity at Porter), but in that case why not terminate at Porter, or reclaim part of the bike path to terminate at Davis?
My particular nitpicks notwithstanding, it's a very cool map and a cool concept!
