whighlander
- Aug 14, 2006
Expanding TF Green or Manchester and running some sort of transportation between them would be a simpler solution than expanding Hanscom (not to mention building an entirely new airport in the middle of the harbor). The distances between either are closer (~1 hr) than between Heathrow/Gatwick (~2hrs), so it's not an entirely unworkable solution.
Uground -- the Greater Boston Region which encompasses Eastern MA, RI and southern NH has its 3 airports and they are ideally situated -- car-less connectivity between them could be improved though it is already not bad:
1) TF Green to/from Logan -- will soon be under 2 hours via CR to Green & SilverLine to Logan
2) Manchester to/from Logan -- less than 2 hours (ideally) via the shuttle to/from Anderson in Woburn and then the Logan Express Bus -- somewhat longer taking CR from Anderson and then Orange to Blue to Airport Station and shuttle to terminal
If there is a need for another airport its in Northeast corner of the region -- right where Pease is located -- non-car access could be accommodated by providing a Porthsmouth stop on the Downeaster / Haverhill CR
Logan should be the hub airport for international flights, long haul domestic and high value air freight with a smattering of the shorter flights to accommodate the people living / working close in
Hanscom and Worcester should be high value general aviation with some limited air freight and some very limited commuter flights to near by destinations
