bigeman312
- Jul 19, 2012
It's worth remembering that the stops aren't randomly placed - almost all of them are at significant cross streets where much of their ridership will be walking from. Moving stops to midblock, as was done on the B, is often counterproductive by making longer walks for people coming from both the former stops. Merging Kent and Hawes at Amory, and Fairbanks and Brandon Hall, are the only two locations on the C that I think make sense.
I've never been particularly convinced about needing to remove Dean Road. It's not actually that close to Beaconsfield - about a 900 foot walk, the same as to Tappan Street or Englewood Avenue. Moreover, because it's only two stops from the terminal, the only people whose trips it delays are those using Cleveland Circle or Englewood Avenue. I'd rather see improvements further east on the line - in particular, closing some of the closely-spaced grade crossings like Centre and Pleasant - that would benefit more riders and not give anyone a longer walk.
From the beginning of messaging, the B consolidations were messaged as such: "The proposed project would consolidate the BU West, St. Paul, Babcock, and Pleasant stops into two fully accessible stations that will help reduce travel times and improve safety."
I agree with your thesis, but with some disagreement on details. This stretch is less of a super-block situation that the recent B-Branch consolidation stretch of Comm Ave, with much more porous access from side streets.
If one wanted to remove Dean Rd, you could shift Englewood Ave to be just east of the Englewood/Beacon intersection without creating a mid-block problem as you describe.
I will grant you that you have a point with respect to Tappan St. In a perfect world, that u-turn is eliminated and the crosswalks from Tappan and Williston become the eastern end of the stop, rather than the western end of the stop, thereby not increasing the walking distance from either street.
Other than that, I agree with the rest:
- Fairbanks St and Brandon Hall make the most sense for consolidation.
- Kent and Hawes can go 2 -> 1. Personally, I think the current location of the Hawes St stop, presumably with platforms lengthened westward is the best solution, but that’s a nit and not a hill I’d die on.
- The other six stops (Cleveland Circle, Washington Sq, Summit Ave, Coolidge Corner, St Paul St, and St Mary’s St) are in the right locations, with the only possible exception being St Mary’s St, but it’s in the best location given the location of the portal, and messing with that is out of scope for this discussion. We definitely see eye to eye there.
