- Oct 14, 2009
im sure that by the time this things built in a few years theyll have plenty of time to figure out an easy way people can get to and from the train
There's an elevated AirTrain loop from the SFO terminals to BART.San Francisco airport is directly on BART, no shuttle bus.
At the terminus (Transbay Terminal) of your HSR trip from Los Angeles, you might need a shuttle bus to the nearest BART station --just a few blocks away, but an eternity when struggling with luggage on city streets.
Logan's probably the shittiest large airport in America.
I guess you haven't been to LaGuardia or Miami International!
I guess the things that would make the biggest difference are connections between terminals, and more importantly, a connection directly to the T.
That subway line is a depressing introduction to Chicago. Lurching its way, slow painful stop by painful stop, through the city's neverending impersonation of Dorchester, it makes you wonder if you're on a Moebius strip of slow transit. If you could figure out how to get off and over onto the other side, you could maybe find the plane you came in on still on the tarmac, and go back home.O'Hare is better, as a subway line serves it directly.
And that will happen before 2150 --if at all.No, the transbay terminal is supposed to be home to BART via a 2nd underwater tube.
