Charlie_mta
- Jul 15, 2006
SFR viaduct over the westbound surface Pike vs. over the eastbound surface Pike (I did the eastbound version):
If you mean this IMP, I'm pretty sure it doesn't include any land directly related to the I-90 project.
There is going to be at least a Cambridge Crossing's worth of commercial and residential development here.
Over a longer-term time horizon, develop an Enterprise Research Campus in Allston Landing North, creating a gateway to a collaborative community for business, investment capital, research, and science development.
Nice job Charlie with the layout.
Aesthetically, putting SFR over the eastbound side of Pike is preferable, imo. But I am sure that would add cost and time. I still can't get over the fact that they're projecting this will take 8 years. That seems excessive. How come this can't be done in 3 years?
They're adding what looks to be a pretty substantial amount of space for bikes, pedestrians and open space all while maintaining the much needed road infrastructure. Should be a nice upgrade.
Knock this part of the BU building down and you can ground the whole thing.
Congestion pricing would render the capacity of SF/Storrow unnecessary in the first place. You can set the congestion price to whatever brings demand below the capacity of your roads.
That said I do think Storrow Drive should be "fixed" in some way. But I also view that in providing equivalences - like adding ramps to the turnpike or other means (like bringing back the A-Line or Urban Ring or more driver centric like covering up Storrow) so true throughput in the transit of people remains the same (quality of replacement also needs to be factored - turning to the A-line to replace Storrow is not equivalent if it has to deal with the B-line's speed). Just throwing in congestion tolling does not achieve this.
Ok - first, this is actually one of the most "crumbling" bridges in the State, and one of the largest in poor condition. By your metric, replacing it should be a pretty high priority, and it has nothing to do with Harvard.
I'd like to see those metrics...
https://geo-massdot.opendata.arcgis.com/datasets/8fa67bf47651417283813a29bfc31545_0
Use the "Structurally_Deficient" field. Deck area isn't in here, but you can use the length as a reasonable proxy for the "bigness" of a structure.
I think nearly anybody who talks about congestion pricing is implicitly making this argument. The revenues from congestion pricing should be dedicated toward non-car transportation. You do want to maintain the same throughput of people, after all.
Removing cars from the city makes the city more desirable and increases demand. This allows still more road space to be dedicated towards other uses like pedestrians, bikes, and transit, and this becomes a self reinforcing virtuous cycle.
This requires acknowledging that, in cities at least, the liberation that cars provide is, on balance, more than outweighed by the oppression that they cause through their tyranny over the public realm. Boston, and every other major American city for that matter, continue to stand on the precipice of making a change, but so far none have taken the plunge. But this is what you see in many European cities so, to me, there's no reason to think otherwise.
But to be honest, the specific case of Soldier Field Road and Storrow Drive, to me, seems more like the Embarcadero situation in San Francisco
Let's keep this in perspective folks. The proposed viaduct is only about a 1/4 mile long. That's about half the length, less than half the width, and shorter height than the existing structure. With even an ounce of design effort this can be as visually appealing as any bridge in Boston. It could be a 1/4 mile long mural that becomes an icon of the city. The assumption that an all at-grade solution would be more visually appealing is short sighted, I think. The idea that an at-grade solution would/could be decked and developed is pretty unlikely.
Yes, I've discounted the decking concept... I just don't see the benefit in spending 8 years of disruption, spending tens of millions... even hundreds of millions more over an in-place refurbishment to simply shuffle things around a bit and end up with basically the same elevated highway in the "throat" area but even closer to the river than before.
Just leave the existing configuration alone if you can't significantly improve it.
We can save a lot of money (enough to fix maybe 5 or 6 other bridges) and just keep the throat area using the same highway configuration refurbishing the existing structures just shifting lanes back and forth to do the work.
They can realign the ground portion to make way for Harvard (let Harvard pay for it) and just build a short new span to ramp up to the existing elevated viaduct.
Seems people had grand ideas and then we have gotten compromised back down to a plan that spends a lot of money without really much benefit except for the companies spending 8 years doing a lot of busy work shuffling stuff around.
But throughput remains throughput. A system (system mean not just roads but I mean in all sense of able to transport people to their destinations), can carry so many people. Reduce one line, you'll reduce the maximum capacity of that throughput. Putting congestion pricing on it doesn't change the desire. People will point out every time that people will go in other times or other modes or other means. But that's the thing, the reason people chose what they choose is from what is find to be the most optimal for their lives. Thus to start charging is not solving the desire for so-and-so person wanting to drive at so-and-so time, but making it less attractive. Not making the other options better - the other options remains the same, just the previously chosen options worse.
