atlantaden
- May 31, 2006
Cool as Terminal E is, I won't be happy until Massport catches a clue about really connecting public transportation. We need a smooth, non-bus connection to the T.
Next time I'm stuck on one of the airport shuttle busses I'll put a microphone near the front shocks and luggage racks and record when those stupid busses go over a bump. It sounds like somebody dropped a hamster cage onto a steel door from three stories up! We've all been trained to suck it up and just accept the noise without realizing how nerve-wracking and jarring each noise is. That goes without mentioning the cold/hot/wet wait outdoors, the plastic seat discomfort, the diesel stank, the filthy windows... the overall lack of attention paid to the non-car Logan visitor. It makes us look low-rent, old... and just plain mean.
Instead they actively made it worse when they opened the added the Rental Car stop to the bus system, made the Rental Car stop the bus layover (more than once I've been told to change buses there).No disagreement here. It's an embarrassment and we need a better system.
That said, as a Blue Line rider, I'd be pretty happy with some more pedestrian consideration between Terminal E and Airport station. It's a pretty easy walk from Terminal E (Google says 14 minutes, for me it's typically 10) and a direct one too. But it's a pretty desolate walk with no trees/plantings along the sidewalk and a complete lack of crosswalks at the first set of lights entering the station from Service Road (to cross legally, you have to walk a little further, cross Cottage St, and then Service Road, and then another small driveway). It's unnecessarily circuitous and there's nothing even remotely inviting about what is otherwise an extremely easy connection for the traveler that's willing/able to make the walk.
The people mover is badly needed, but it would probably result in the opposite problem: getting to A from Airport would take a long time. At least it would make SL3 an actually useful way to get to the airport (and Red-Blue + Peoplemover would really decrease the issues with SL1)
I think it's probably a reflection of the airport road network being basically a series of unidirectional counter clockwise loops more than anything else. It's not too difficult to get from the Surface Road and Airport to the RCC, as it's a straight shot, but doing the inverse motion you would be basically a figure of 8 to then get to the terminals. That said, I do agree that not every route needs to go there - they already have the 2 RCC routes (22&33) - the 55 which is sign posted for the station it primarily serves doesn't also need to stop there.If the people mover stop were near-enough to the parking lot bridge at E, it'd probably be a decent shortcut to cross to A that way (at least if the moving walkways weren't broken).
That was a very noticeable downgrade in service. I'm sure there must be some people who come in via the Blue Line to get to the rental car center (though, probably not many), but most of the people getting on the shuttle at Airport are presumably going to the terminals, so naturally it makes perfect sense to make them all wait for an indeterminate period at the rental car center none of them are going to. (Seems like it would be faster and more efficient to separate the RCC out on its own route, but that'd probably require more drivers and buses.)
I love that this mockup doesn't even connect to the Airport T stop!I think it's probably a reflection of the airport road network being basically a series of unidirectional counter clockwise loops more than anything else. It's not too difficult to get from the Surface Road and Airport to the RCC, as it's a straight shot, but doing the inverse motion you would be basically a figure of 8 to then get to the terminals. That said, I do agree that not every route needs to go there - they already have the 2 RCC routes (22&33) - the 55 which is sign posted for the station it primarily serves doesn't also need to stop there.
As I recall, part of the people mover plan was to include a intermodal Transportation Center somewhere around the Limo/Bus holding area to accommodate all ride app, limo/taxi and water taxi/ferry riders - the advantage of a people mover is that it doesn't have to follow the counter clockwise pattern, and can be bidirectional. Further, based on the last render I saw, it would have actually served the terminals in reverse order from the T stop, going to E first before ending at the RCC.
And it's unidirectional. Have these guys been to other airports? There should be one arriving every 2 minutes in both directions A to E and E to A.
Adding obligatory edited image to show how short they were from yadda yadda yadda intermodal connection...
View attachment 27455View attachment 27456
It looks like a half-ass solution. A 2-way loop would be best but a 2-way MBTA dead end would work.My recollection of the proposed APM was that it wouldn't be a loop, but would run in both directions between stations at (well, adjacent to) the Airport T stop and the vicinity of the Rental Car Center, serving all terminals between those end points. The original rendering cuts off the area of the T stop, but you can see below Terminal E that the APM track continues out of the frame.
I'm imagining myself riding on one of those little red tram cars on my way to Terminal A after narrowly missing a piece of falling metal on the Airport T platform.
I get off the T and have to...
Board tram at Airport MBTA Station >travel>Terminal E >travel> Terminal D >travel> Terminal C >travel> Terminal B >travel> Terminal A.
...No matter what.
The reverse option should be available.
Airport MBTA Stop >travel> Car Rental >travel> Terminal A >travel> Terminal B >travel> Terminal C >travel> Terminal D >travel> Terminal E >travel> Airport MBTA Stop
With the existing design, Terminal A gets the wet end of the stick. Built in favoritism toward international travel and bias against Terminal A. That's not necessary. We should strive to save everyone 10 minutes where possible. That's just good design.
According to massport flight status and online maps the B to C connector are open
I'm seeing that on A.Net too. I'll try to grab some shots tomorrow.
I swear... it's like the bus drivers designed this concrete craptacular to protect their jobs! You couldn't design it any worse!....There's a giant clump of highway ramps completely surrounding the Airport T stop headhouse...
I’m thinking there wasn’t much foresight about a future state then. By the way they located the HVAC and power sheds around the Airport T stop and how little space was allocated for any sort of tram system it means we’re going to have to do a little property acquisition.I mean, the interchange the T headhouse is under has been there in one form or another for decades. Presumably they figured it made sense to build the big nasty highway interchange over the railroad because there weren't any houses or buildings there that'd have to be knocked down. And it's not like the T was going to re-route the entire Blue Line when they rebuilt Airport Station.
