This particular photo was included in the 9/14 Bus electrification presentation to the FMCB, but it was probably taken at the NFI facility in Minnesota prior to delivery, given that's what I think is a NYC MTA bus peeking out in the background. I would be surprised if they didn't test the overhead charging system prior to delivery. Given 1295 was the first unit delivered, this was probably a pre-delivery status update/ promo pic.
The proposal in whole is reasonable, except for the fact that the needed bus doesn't exist yet.
NFI at the moment makes available a 3rd party option with the Xcelsior TT but I don't think 25km is viable for anything other than bridging down wires or short non rev moves, once you account for 40+% range losses in extremes of weather. And, I don't think the Cambridge carhouse on mass ave has the space available immediately for what would be a bigger fleet.
North Cambridge doesn't, but Watertown certainly does. West-region 40-footer load reliever garage would be an ironclad requirement for the extra bodies needed to run a full-on BEB network, but the fact that it can instantaneously close North Cambridge for any/all heavy repair if reanimated to any degree makes Watertown an ace-in-the-hole.
Figure if they wanted to put the full 77 on a TT/BEB hybrid for on-wire charging that's enough impetus for extending the Mass Ave. wires half-mile further to the Parkway then along the mythical Alewife-Mass Ave. busways for a 600V DC interconnect at Alewife substation. If they remanicure the Alewife Station busway to have wired side-parking turnouts for 3-5 layover 77A's at a time + 1 inspection pit with onsite toolbox for quick maint/troubleshooting, that's enough to completely sell out the 77K+ sq. ft. backlot at Trolley Square for more private development and lump all home-garage duties for the TT's at Watertown.
At minimum the 77 and 75 should be good enough to trial for on-wire charging since that's a goodly amount of wired territory before they diverge (the TM map is not quite to-scale...Arlington Heights isn't nearly as far as it looks from North Cambridge, and Medford Square on the 96 isn't nearly as close as it looks). 74...I dunno, probably have to play that one by ear to see how the charging ranges go. It would have to be a really good quick-charge with only 3/4 mile of wire to play with, but since the 74 is a pretty taut route quick thumbs-up/thumbs-down shouldn't be hard to determine on the charging range. 78's extreme wishful thinking at this point and 96 is way out of range. But...doesn't take many scores off the TT network to achieve some impressive scale.
- Alewife busway build strongly beckons the hyper-local 77A to Alewife Station with a wire extension, so it can mirror-image the 79 Arlington Heights-Alewife on the corridor. Regular old TT...wire extension is too short/cheap for dual'ing unicorns.
- 71 is ripe for BRT features like more imposing bus laneage, signal priority, and 60-footer TT's. 1/3 mile wire extension to a Newton Corner loop at the to-be N.C. Urban Rail station makes it a very important radial BRT route to Harvard from Regional Rail, and the ex- A Line trunk feed is still active under-street as a DC interconnect between the B Line and 71 so would be near-effortless on cost literally only requiring the pole + spools-o'-wire + hangers hardware and nothing more.
- Full-route 77 is the poster child for an in-route charging BEB rollout, since the corridor (esp. if the 77A got its wire extension) would be split pretty close to even on vs. off wire mileage, and the stop turnout at the Parkway would--with the Alewife busways--be a busy enough crossroads of route transferrage (esp. if Route 16 got some radial-spanning BRT between Red, GLX, and OL-Wellington) to fit an automated trolley pole raise/drop into the default boarding dwell. I would think this is also worth shooting for 60-footer TT/BEB's.
- Watertown Garage reanimation checks off lots of boxes on the Bus Facilities Master Plan...both across-board frequency expansion via load relief for Charlestown and Albany, and also for the fleet extras needed to go wholer-hog on BEB rollout. And direct-serves a large real estate redev slab at Trolley Square in the tradeout from tiny North Cambridge garage. Sort of same domino effect with Watertown direct-serving the 77K sq. ft. redev trade in Trolley Square as future Wellington Garage direct serves a Fellsway Garage flip for Medford redev (165K sq. ft. T property + 285K sq. ft. strip mall & car wash as super-slab).
- If all goes well with the base builds on the keymost routes, then BEB technology should catch up enough to make the 75 and 74, respectively, be next-targets. Also not out of realm of possibility that we can do something in-route charging wise with the 57 if it's sharing Galen St. with the 71 extension. While I can't see Newton ever agreeing to string wire back on Tremont St., presence of the 600V DC trunk underneath the whole way to Packards Corner means the hookup opportunities for quick-charge stations at major stops is pretty good (while obviously those stations could schlep off the B's feed through BU). Kludgy, yes, to attempt a hodgepodge of charging scenarios. But presence of that 600V trunkline across the whole of the 57's route makes madcap experimentation pretty easy to do here as a proof-of-concept. And if you can rope a more speculative reach like the 57 in with the surer-thing 71/77A/77/etc., then you're really starting off like gangbusters with the in-route charging network scale.
This is really great. We were told originally that TT's were passe and the Cambridge wires needed to be ripped down as first order of business, because reasons. Now we've actually got decision-informing research and the mentality has done a complete 180 to treating the TT's as a crown jewel showcase that springboards the whole BEB network. I feel like it's just desserts for that very high-functioning part of the Yellow Line being shit upon by holier-than-thou pols all those years as an anachronism that now they need it to the hilt as a necessity for launching this politically-charged Jetsons Shit initiative into orbit. Long time coming.
