fatnoah
Wedgemere and West Medford become regular stops off-peak.
What's the practical impact of changing a stop from a flag stop to a full time stop?
fatnoah
Depends on how often nobody was there.
Obviously, but then that begs the question of why trains would stop at location where no one is getting on or off. According to the T, this will "improve the passenger experience" though I'm not sure how no longer having to be visible on the platform or having to inform the conductor of your stop meaningfully improves things.
Koopzilla24
In the off-peak trains are infrequent, so if someone is rushing to make the train and makes it to the parking lot but not platform before the train gets there and it passes. They’ll have to wait up to a couple hours for another. Having the train stop either way makes it possible to catch the train last second and since it’s the off-peak there’s negligible different in journey time from stopping at the two stations. Improves the experience of the customer no longer having to be there early or bust.
The EGE
From my experience, there aren't a lot of times when a train doesn't make a flag stop. Especially midday and early evening, there's almost always at least one person getting on or off. Better to make it a regular stop and have more predictable travel times.
BeyondRevenue
At Wyoming. Where standing on the platform you can see Oak Grove (snark over).
Im assuming you are referring to the new developments right on the Melrose line, but those are 95% residential and aren't really a draw for any CR commuters. Most of the walkshed is SFR on Main St, Pine Banks park and the Fells. Considering Malden Center got less than 150 riders per day pre pandemic, Im not holding my breath Oak Grove would do more than 30.
In my opinion, it’s degrading service for essentially every Haverhill line rider to serve a few dozen passengers who already have excellent bus/subway options.
I was talking with a friend of mine about how Melrose prohibits the Orange Line for racist/classist reasons and how the OL should replace the two southernmost CL stops. He said that Melrose has great MBTA CL access already. I countered that the Zone 1 privileges Melrose enjoys adds ten minutes to a Haverill train… and that is also kinda racist/classist by design. I’m just wondering how that town holds on to 3 CL stops. Kinda gluttonous when other town get passed by elsewhere. Thoughts?
tysmith95
Same with how closely spaced the Winchester stops are, before Winchester center closed. Winchester center is the only one dense enough in that town to deserve a transit stop imo.
Brattle Loop
They stick around because they've been there forever and are reasonably well-used, meaning that any time they're proposed to be reduced (and the T did suggest closing Cedar Park in the pandemic closures, though F-Line for one thought that was more about a dispute over the fact that city gets the parking money rather than the T) the locals cry havoc, and the politicians listen. Needlessly antagonizing the politicians isn't generally advisable, and the level of discontent tends to be higher when you're proposing reducing service than simply not expanding it.
It doesn't really cost the T/Keolis much of anything to keep those stations. The time cost isn't hugely meaningful for a full Haverhill Line run, and is (notionally) mitigated by designating them as flag stops for at least some of the trains. And I'd guess they do enough business to cover the costs of upkeep on the quite bare-bones facilities, so it probably is mostly a "don't piss off the politicians" for no meaningful improvement. (And any local politician who suggests reducing service in their town to allow for more equitable improvements elsewhere is likely to find themselves a former local politician quite quickly.)
Also, it's Melrose. The town likes it this way. (Would have made my life so much better if the OL ran here when I was a daily commuter...this city's priorities are...odd.)
Wyoming Hill, the least-utilized of the 3 Melrose stops, does almost as many boardings as all seven of the pandemic-closed stops put together (Hastings + Silver Hill + Plimptonville + Prides Crossing + Mishawum + Plymouth). Cedar Park, the one they were trying to make as the 8th one closed...exceeds the other 7 put together handily.
These are well-utilized stops in dense walkable areas, with stop spacing that's just about perfect for Urban Rail service. There's no flaw here that needs to be 'fixed' with a closure. And the Rail Vision already has a solution for speeding up Haverhill run times: run it via the Lowell Line + Wildcat instead of Reading, like it used to in the old days.
tysmith95
Electrification would fix a decent chunk of the time loss from closer spaced spots.
They should reopen Mishawum though.
Highwayguy
If the T went to the town tomorrow and said we’ll do an OLX to Wyoming ( or Reading), Melrose would be 100% on board, no? I think its an Arlington situation where the opinions/ incentives RE rapid transit have shifted 180 degrees since the 70’s / 80’s; the towns want it (or would at least be neutral) but the T can’t / won’t deliver.
Regardless of ridership, those 3.5 Melrose stops (including Oak Grove) are brutal for everyone North of Reading.
Brattle Loop
Melrose, 100% on board with anything? :ROFLMAO::ROFLMAO::ROFLMAO:
I think there'd be a decent base of support, and a virulent, vocal opposition. (Though we get conniption fits here when they install a stop sign, so...) I'd be curious to see, but I definitely don't agree that we're necessarily in a situation where the town would want/be neutral towards it. There's already more than a bit of consternation over the state's efforts to increase housing density here (you'd think they were building something the size of Millennium Tower, the hysteria some of these really-quite-modest developments generate), and the OL would only exacerbate that. (I wouldn't call that outright racist scaremongering like in decades past, but definitely a "the city's already too full" thing that's definitely classist in the "we made it enough to not have to live in density" kind of way.)
Oak Grove sticking around on the schedule didn't make a ton of sense to me post-shutdown, but I definitely agree with the broader point that that those stops collectively drag on the schedule in a way that's annoying for the Haverhill runs (which, of course, they weren't part of when they were opened and for a good century-plus thereafter; the Reading schedule is short enough that they're not meaningfully problematic on the Reading short-turns).
bigeman312
Can the right-of-way even accommodate a +1 to Wyoming Hill while still retaining Haverhill Line service through Melrose?
I imagine that of feasibility was of no concern, Melrose would be mostly in support of such a project, but I am unsure of feasibility. I’m sure someone on here knows. Thoughts?
Riverside
Maybe I’m misunderstanding, but AFAIK the conventional wisdom is that Haverhill trains will be rerouted over to the Wildcat Branch if any OLX happens. That being said, that would make a partial OLX more challenging (eg any build that doesn’t go all the way to Reading).
bigeman312
That was my understanding as well. Hence why I'm questioning the feasibility of what Highwayguy suggested.
It would be problematic. The ROW is barely wide enough for 3 tracks, and pinches tight right after Oak Grove alongside Banks Place. There's no room for tail tracks unless you eliminated the grade crossing, which negatively impacts Orange's resiliency if you have nowhere to stuff an out-of-service consist. The egresses would be very constipated if the CR grade crossing stayed. And unless you eliminated the grade crossing you basically preclude any further Orange extension lest you need to blow up WH and start all over.
Basically, it would be hacky at best if you tried for a stub-end right before the crossing. You really need to eliminate the crossing to give everything space, and that's more expensive in the absolute and considerably more expensive when trying to preserve the CR track because then you need longer inclines for gentler FRA grades. It's probably not going to rate very well when you weigh the compromises of trying to do it cheap with the expenses of trying to do it right. Probably doesn't go on the board unless you go whole-hog to Reading.
