RandomWalk
- Feb 2, 2014
Until relatively recently, South Acton was where the double track ended.
Just keep it for the layover, because there really isn't anywhere else good to put that. And even if you are rapid-rotating sets for :30 service you're still going to have to swap sets every few trips for basic cleaning, which will necessitate a layover trip. The backup move from Cordage or Downtown would be somewhat annoying, but isn't off-scale disruptive relative to other layover locations on the system. Deadheads could easily clear the junction switch within the headways of :30 all-day service.
I'm surprised that they don't appear to want to tie into the Newport Ave/Rt 1 bridge, from which this station will definitely looks as if it should be accessible; instead, there will be a solid gap between the bridge and the station access structure, which will be at near enough the same elevation. Why not encourage walkability and access from the south/RI? It'd be, by far, the most visible access point.
1) Owned by MassDOT, 2) Its a lot better than what was there before, and 3) that overpass was fully rebuilt in 2009-2011, so there really shouldn't be any significant deferred maint.1) Turf issues: I assume the T does not own the overpass and doesn't want to work/is discouraged from working with the agency who does
2) Narrow sidewalk and other pedestrian hostile aspects of that overpass. I mean, seriously, that sidewalk is terrible, and would be worse with a stream of commuters walking down it.
3) Something to do with the structure of the overpass itself -- i.e. "if you even just barely touch it, you'll then be required to do a lot of deferred work"
1) Owned by MassDOT
The 30% Design submission from the 3/4 South Attleboro presentation is out; its got a surprisingly fussy wavy roof and canopy treatment, which I fully expect to be VE'd out - notably, the renders already disagree.
I'm surprised that they don't appear to want to tie into the Newport Ave/Rt 1 bridge, from which this station will definitely looks as if it should be accessible; instead, there will be a solid gap between the bridge and the station access structure, which will be at near enough the same elevation. Why not encourage walkability and access from the south/RI, and attendant population density? It'd be, by far, the most visible access point.
Guessing the trailer parkers don't use the CR.
They've begun demolition activities at Winchester Center Station. Here's the presentation from the last public meeting:
Winchester Center Station Improvements Project Final Design Update (mbta.com)
Now would be the time to build it as station to accommodate connections onto the green line.
