They should build the original art deco tower that the Great Depression stopped.
This needs to be Dev Forum'ed:
- WAT'S TEH FAA HEIGHT LIMIT 4 CHARLZ?!?!
- DEPRESSION WUZ A BUNCH OF SHADOW NIMBYS!
- MOAR SPIRE!!!
Wait... it's happening?
Holy shit! I never knew about this. Great pic.They should build the original art deco tower that the Great Depression stopped.
Good question. On one hand, it would provide the opportunity to eliminate some truly nasty curves, which would make future rolling stock orders cheaper (and perhaps even allow fewer-but-longer BL cars, which would add capacity).
On the other, simply using the existing yard would be vastly cheaper, allow construction of the extension with basically no impacts on service, and keep the station open. The ideal scenario would be to leave the existing station while constructing the extension ASAP, then come back later to modify the station with smoother curves and elevators.
I think I'd much rather see them bulldoze the existing station and just close it for the duration of construction. With MGH as a terminus with questionable tail-track space, that GC to MGH stretch can already be a significant headway-limiter (like the Alewife switches). Only thing we need is another 10mph curve to gum it up.
Bowdoin also has pretty minimal ridership (1500 on a weekday, I believe one of the lowest in the entire HRT system), so sending all of those to nearby Gov Center is not a big disruption. But knowing the MBTA there is 0% chance this will get done.
Edit: For stop spacing, Bowdoin should get eliminated in favor of MGH anyway...
I'm with you. They missed the chance to render Bowdoin truly redundant when they made the northern BL platform access emergency-only. Nonetheless, the Blue Line has an absurd number of stops Downtown - 0.6 miles between the Marriott Long Wharf and Bowdoin Square, 4 sets of platforms. Honestly, the T should be looking into eliminating State as a platform stop as well. Rename the State OL stop "Government Center" and connect it to the rest of the station with pedestrian tunnels.
Would there be room to do that between all the basements?
I question if it's a good idea even if it were possible. Having a direct connection to the Orange line (as roundabout as it can be at State) is vitally important. Adding a huge amount of extra walking from GC would be a major issue.
