BostonUrbEx
- Mar 13, 2010
Take a gander, this is what I've been doing for an hour at 2AM:
http://www.google.com/maps/ms?ie=UT...249,-71.039143&spn=0.074285,0.181789&t=h&z=13
It started with an idea to remove the curvy sections of US-1, particularly in Chelsea, and then coupled with Van's uncompleted Boston highways map. MA-1A was supposed to be a full built highway and from the looks of it, and was even going to Copeland Circle to meet I-95 immediately before the circle, pretty much meaning my path for an improved US-1 follows that almost exactly. The only difference with mine is the existing US-1 south of Copeland Circle would be obliterated, and obviously I-95 through Lynn was never (and hopefully never will be) built.
I want the current ROW through Revere and Chelsea to be brought back to grade as much as possible, and hopefully fill it in with some form of rapid transit. It would probably be elevated, but not running over a street. I hope that this will better connect the two sides of US-1. As for the new US-1, as soon as it curves south off the marsh, it would begin a downward grade so it passes under the small bit of neighborhood in that area, allowing even better connectivity than at present. And again, the same thing at Bell Circle to allow better connectivity than at present and no big jumbly intersection (although, the rail trench is still there, hopefully air rights could be sold there).
I kind of wish the Pike extension never happened as that kind of defeats the new tunnel and interchange with I-93 under Rowes Wharf. It could have killed a few birds with one stone. Alas, the routing could always go via the Ted, but it is so terribly out of the way...
I'm sorry I don't organize my thoughts better. I'm always quick to toss things up here... So any questions just ask. Comments welcome too. And criticism as well (you can call me an asshole if you feel compelled to do so, I need to know what people's blunt honest reactions are, as this is something I would honestly like to see perused).
inb4"another big dig?" (this would be a better use of $22 billion, IMHO... and I doubt it would cost that much)
EDIT: Note that the ultimate goal is to get rid of I-95 between the Topsfield/Danvers circle thingy with US-1 and 128 in order to consolidate two highways into one. Thus, merging US-1 and I-95 to run concurrently.
