Portlander
- Apr 14, 2010
This is the area at PWM that has safety distance limitations imposed by the FAA (all airports have to conform) due to positioning of the aircraft tails, ramp vehicle movement and an active taxiway. The black and yellow line is the absolute limit for aircraft movement on the taxiway due to required push back space and there is just no room to widen. Now the grass areas of the taxiways that are away from the apron could be wider but then you run into alignment and lighting issues which is just not worth the effort.
PWM is a compact airport with limited available land to change the basic layout which has been in place since 1968 and planners back then would not have predicted that over 2 million passengers would someday use the airport. Fortunately the primary runway was extended from 6800' to 7200' but even that is maxed out due to the Fore River on one side and the Maine Turnpike on the other so we basically have to work with what we have.
