- Oct 14, 2009
I wasnt implying using track 61. If they can propose the ginormous north south rail links they can propose a tunnell in southie.
Because any tunnel you cut across the Channel...anywhere...blocks the last path for ever constructing the NSRL. The Big Dig only left slots open for threading north-south tunnels between east-west tunnels for the Alt. 1 (Dewey Sq.) and Alt. 2 (Dot Ave.) alignments of the NSRL. There are no new east-west tunnels that can be built without blocking the NSRL.
Dig anything new along the waterfront...no NSRL. Forever. Simple as that.
Second...I repeat: why are you proposing another billion-dollar tunneling job through Southie before doing Red-Blue and the Green-Transitway connector? Those are hands-down the two proportionally hugest downtown congestion relievers, because they actually tie together destinations into and through downtown while load-spreading spreading away from SS/DTX/Park. There is no substitute Option #3 that does the same caliber of load-bearing. Certainly not one that comes in the form of a neighborhood loop-back that doesn't reach anywhere across the other side of Dot Ave.
Either justify the Southie Branch in terms of what congestion looks like after you've saved up the $2.5B to build the other two critically important ones first, or it's a eye-of-beholder boutique project that wastes the same $$$ for a fraction of the benefit. The numbers don't lie which downtown subway digs are head-and-shoulders the highest-impact. This has been studied to death for 40 years.
1.
2.
Never said anything about it being built before or after any other project, or that it was more important than them. My question is why has this never been proposed.
The reason I presented this is because in 10 years in my opinion the seaport is going to be in dire need of rail transit. This area is going to be the size of downtown with no rail line whatsoever. It may not be very important right now but in the future it is going to be very important. Red to Blue-very important, NSRL-very important, rail transit in seaport-will become very important later down the road. Im not saying build this tomorro, but so far I have seen almost 0 ideas other than the single track 61 dmu which has to wait for a shit ton of right of ways before it can meander down its single track to the convention center.
This would not just be for the seaport. Southie as a whole barely gets touched by rail transit, so a major neighborhood in Boston and the new waterfront innovation district have almost nothing in the way or real transit. This would go through the heart of southie serving lots of people there and also in the seaport.
Get track 61 done soon and then some time 15 years in the future build this and South Boston becomes very well served by rail.![]()
1.
2.
Okay. So is there a real green line extension to southie proposal or is it just talk on here? Are there also any real SL under D proposals, I would be interested to read both.
I get it, red line is a bad idea. My point I was making was there are proposals for all kinds of shit way off in the future, but there is nothing at all in the works for the seaport which the mayor and other important people have said needs to happen. Its just weird that nothing even far fetched is being tossed around here by anybody outside of this website.
In the mean time I expanded on the green line idea. This would use the existing silver line tunnel, upon the exit would make a right turn onto D st, follow D. st and make a left turn onto w broadway, another left onto e broadway where it would continue down broadway as far as needed. It could turn around, reverse direction, or even follow summer st. back to D st. If the track 61 dmu station were to be in front of the convention center there could be an indigo-green connection there. The logan connection would be solved when the red to blue connector is put in,NSRL, and a new aquarium station with commuter-blue line connection, seeing that orange and green already are connected to the blue line. Both this and the red line I showed would require new tunneling and Im not sure how this would be able to connect into the rest of the green line. The red line at least would essentially be the same line just moved over a few blocks.
We've hashed this out elsewhere as well, and I agree with Jeff. Southie residents won't want any rail up the gut of the neighborhood. Rail-in-road should be looked at more, and should be included in any feasibility studies - if only to absorb political ire - but it likely would be rejected for Southie.
Easiest incremental way to get GL to Southie would be to the transitway conversion to dual-mode; have GL trains peel to the south out of the portal and stop at Boston Design Center; either overbuild or track-in-pavement the new haul road they're building that will get semi-trucks off of 1st St.; GL trains share that restricted access road with trucks; terminal and only station in Southie proper, "City Point" north of E1st St but east of OSt. Then serve most of Southie with frequent key bus routes either up the gut on Broadway, or flanking the neighborhood on the north and south that gives more residents a <10min ride to either Andrew or City Point
Something like this (with the terminal perhaps a thousand feet west to avoid land-sharing/swapping issues with MassPort)
^I would love it if we got some new Green Lines that all terminated at major parks... You could get one to Franklin Park, another to City Point, maybe Arborway (as discussed in the CTP threads...)
But really, really really really, why is the state govt so insanely inept on transportation? If any region NEEDS a truly new transit solution it is without question the Seaport... Im as cynical as they come, but I just dont get why every time there's another press story about Seaport transportation it's some stupid panel that's going recaliber a traffic light or work more with private bus carriers... just asinine.
They're terrified of finding the money, and they're terrified of suburban voters who only think about their cars. It's really that simple. What we need to be doing is start pressuring the city so that they can start pressuring the state.
Busses -- Forget the Green Line -- its time to focus on making positive contributions by suggesting achievable, realistic improvements to the Silver Line
