massmotorist
- Mar 27, 2012
A few things I didn't mention before:
- The Pike isn't under capacity, it's over capacity, it's just less over capacity than most other Boston roads.
- The Pike inside 128 uses a barrier toll system. It only works because there aren't nearby exits available to game the system and get off just before the toll. People will spend $2 in gas and 10 minutes in congestion to avoid a toll, don't ask me why. If you eliminate tolls (as I'd prefer) that problem goes away, of course.
The key thing people don't get about Storrow is that it acts as a hybrid between a major arterial and the closest thing to a Pike collector/distributor road that we have. It serves primarily to get people on and off the interstates efficiently for relatively short trips.
The distinction between an interstate freeway and major arterial or C/D (limited access or not) is really important to recognize. 30k cars get off/on in Allston at the barrier toll and 70k get off/on at the Leverett Connector every day. Local roads couldn't physically move that local traffic to the Pike or 93/1 as currently configured. And you can't just add more ramps, even if there's room - even ignoring safety issues it would decrease the Pike's capacity significantly even while dumping a lot more traffic on it because of the massive amount of weaving and merging it would create.
Ant, I think I hear what you're saying with the decking. A bunch of covered areas like these, but without roads and maybe with buildings on top, at least in certain areas. My bet is it'd be relatively cheap and easy to depress it a bit (say, 8 feet) and they could alternate boat sections with covered sections in a way that would make you barely notice Storrow was there. Probably could bring the height up to standards too so you could move truck traffic onto it.
