The EGE
- Jun 29, 2013
Great work you two! One or both of you got most correct; a few still remain open.
1: Ratmeister got both. Prior to 1987, there was no Dudley-Mattapan route. (The 1 was [re]created in 1962 as a through-routing of existing services. The extension of the 66 to Harvard was during the MBTA era, but the bulk of its route was established prior.)
2: Still open. In the 1940s, Dudley Street only had route 15, with 3-minute peak headways. The 114+115+116+117 (including short turns) combined for about 80-second headways at Chelsea Square.
3: Ratmeister and Alewife got it.
4.1: Still open. The Chelsea-Woodlawn segment was formerly a horsecar, streetcar, and trackless trolley line.
4.2: Alewife got it - the Chelsea Bridge was served by Eastern Mass streetcars until 1934. Full points also to Ratmeister for an answer I didn't think of.
5: Alewife got all, Ratmeister got some. The 32, 1, 66, and formerly 77 were the ones I was thinking of. The 39 in Back Bay was also formerly incorrect. Looking at an old version, I also see that the 111 and 116/117 were falsely shown as not connecting!
6: Alewife got some; 1 still remains. The 1 currently has a grade crossing. The 77 actually used to have two - the Fitchburg Cutoff near Davis Square, and the Lexington Branch at Arlington Centre. I believe the crossings on the 111 and 116/117 have all been separated since at least the early 20th century, and the Dorchester Branch bridge at Wolcott Square over the 32 dates to 1898.
7: Ratmeister got it.
8.1 - 8.4: Ratmeister and Alewife got them all.
8.5: Ratmeister got it.
9: Alewife got it; half credit to Ratmeister.
10.1: Ratmeister and Alewife got it.
10.2: Still open. There's at least 3 answers. (It took me some time with the map to figure some of these out, so I don't consider it cheating to look.)
10.3: Alewife got it. It's been used for special MBTA service and some private-carrier services, but never as the terminal for a regular MBTA route.
10.4: Still open.
10.5: Still open. Central is oh-so-close to being correct: the 1, 47, 64, and 70 will all be through-routed. However, the 83 will still terminate there. There's at least two I can find that won't be terminals at all.
10.6: Still open. The 85 (very similar to the current CT2) will still run between Ruggles and Sullivan. The 86 indeed no longer runs to Sullivan, but I'd hardly consider Reservoir a major bus terminal. I think the only time City Point and JFK have had direct service was a short-lived extension of the 5 in 1987. I can think of 3 pairs of major terminals that will no longer have a direct bus connection, and two arguably-major pairs.
10.4: Still open.
