whighlander
- Aug 14, 2006
Millennium has a setback.
Not from Franklin -- it goes right down 600' to the street
Barely. Still plenty visible from the street. Nothing like what you guys are asking for here.
Context - the interrelated conditions in which something exists or occurs
Seeing a tower at the end of a street is completely different than one hulking over a street for no reason whatsoever. It is out of character, out of context, and out of scale for the street.
Even though the tower is RIGHT THERE, it visually integrates itself into the established contextual relationship of the buildings along Washington.
You don't know this. None of us will know until it's fully built.
Exactly the thinking that lead to urban renewal. "Well, we're doing this for the greater good." The local opinion didn't matter. We need housing, yes, but we don't need to be reckless with the strategy.
I support smart zoning throughout Boston.
The street is what's now out of scale for the surrounding area. Gem of a street or not, policy shouldn't be dictated based on the smallest scale buildings in a neighborhood.
Nope. I have never called it urban renewal. I have been very careful with my wording and consistently said this project invokes the spirit of urban renewal and has the same mentality at its core. I never said this is urban renewal.You keep using that term. I do not think it means what you think it means. If somebody was proposing a bulldozer for the entire block, all of what you've said would be spot on. But this is not that. It is an infill project, replacing a surface parking lot, on the end of the street that is already no longer brownstones and quaint. This will make housing in this neighborhood that you love more affordable to more people, fill a vacant space in the street wall, and not eliminate the good that is already there.
Now I'd like to have a conversation about how to tweak things in a way that helps it to blend in better at street level. But we can't have that conversation when you wrongly label the proposal as urban renewal, dismiss it out of hand as illegal, and make the ultimate defining NIMBY statement of anywhere ut here. There is no credible basis to respond to that in any kind of onjective manner.
How about this. Can someone give me a coherent argument as to why a setback, that has no effect on square footage whatsoever, would not be appropriate? Is there actually any reason why the tower has to be smack against the streetwall of Worthington?
Honestly, I don't see an issue if they set it further back from the street if they can do so without sacrificing units. However, wanting to kill the project because the architect didn't do so in it's first iteration is overreacting as well. I agree that having the tower without it being set back does make it out of context street-level wise but the tower as a whole is not out of context with it's surrounding considering the block it is on contains 3 other apartment towers.
How do you get the same square footage with the setback? You need to go fatter or taller to win back what you lose to the setback.
Fatter affects the tower behind that the developer already owns. Taller sets off its own alarm bells.
The developer isn't an idiot. The architects didn't skip the day they covered context in class. They filled out the space in the way that works best for them and they want to get away with it.
Given our irrelevant zoning code, this is modus operandi. You know this. Data knows this. So ease up on the professional indignation. Something has to give and the developer is going to fight to make sure it isn't his bottom line. They are testing the city's commitment to building more housing. This is what maximizing the number of units looks like. It comes up short on aesthetics to maximize space.
You don't need to be an architect to run through the tradeoffs and see how this building came out shaped like it is. If the BRA pushes back, then they have to settle for less area OR sacrifice views in their other building. Both cost the developer money. If the BRA doesn't care what two dozen residents of one block think then it will go up as-is.
By eliminating the surface parking and/or parklet.
Because there aren't renderings, or anything.
I'll echo Dave's point, what was the reason for the developer lobbing a grenade and alienating the community immediately?
If this building is a "grenade", maybe the problem is with the community.
