I agree, safety and reliability are paramount. How about my 1+3+1+3+1 suggestion from earlier? Or, perhaps stagger the breakdown lanes.
That would not work. That will offer less travel lanes.
1+4+2+4+1 would be better.
There simply isn't enough space in the right-of-way for 12 lanes. The proposal being put forth here would spend a few billion dollars to widen from 8->9 lanes in the vicinity of Savin Hill.
But if breakdown lanes were truly held to be important, then MassDOT would lay out 1+3+1+3+1. But they obviously don't think it's that important to have breakdown lanes.
So in the hypothetical case that 12 lanes-worth of room was magically found for the Southeast Expressway, I hypothesize that it would only be a short while before enough political pressure would turn that 1+4+2+4+1 layout into 5+2+5 with no breakdown lanes, once again.
The HOV lane that runs on the southbound stretch from just out of the tunnel to just before the South Bay area is a joke and only causes more traffic. There is also substantial space along the right side before the exit for Mass Ave that could also be use for example to widen things as you get closer to the tunnels.
I was thinking safety of people (all modes) rather than "safe for big trucks to turn." But that does bring up an interesting point. Fire trucks in this country are very large because most roads have been designed to be very large. And then, because the fire trucks are large, new roads are designed even wider to accommodate them. It's an unfortunate cycle which causes fire marshals to be at odds with city residents, and results in streets less safe for walking, though easier for fire trucks.
Especially given how at any given moment you could reach out of your window in that heavy traffic and grab on to the zipper barrier, which is insane.
Since we absolutely must not ever widen any roads anywhere, it's better to just kill the thing and median-ize it. Then you can have 1+3+1+3+1 but actually effective, or, if the banks are permissive enough, 3/4+3+3/2+3+3/4, which might be the best solution as it provides plenty space on either side to pull a car but physically discourages driving in the breakdown lane.
Of course, if we could widen the road, we could have 3/4+4+1+4+3/4 with the HOV lane killed, driving in the breakdown lane made extremely difficult but getting disabled vehicles into it extremely easy, and still have 8 lanes of travel to work with.
Commute -- my highway priorities are:
1) Finish adding the 2 lanes to I-95 (Rt-128) between I-95 and US-9
2) Build the flyover or redo of the cloverleaf into a sheleighlei at Rt-128 & I-93 north of Boston
3) Fix the Braintree split
4) Add 2 lanes to Rt-3 to Plymouth and make it into I-93 (the wierd piece of I-93 along Rt-128 from I-95 to the Braintree split can be redesignated as I-595
5) Fix R-2 to insure decent Rt-1 like highway travel from Rt-128 to I-495 -- get rid of all of the L turns, rotary, grade crossing of tracks, etc.
Those are some well needed projects. I would also add the interchange in Canton.
What would you do to fix the Braintree split?
Mass -- yes the Interchange in Canton as well as the other major interchanges along that section such as the Rt-24 Interchange would fill some of the later slots in my list
As to Braintree -- ideally there would be a series of splittings of the traffic well separated to reduce weaving:
1) a "Mass Ave-like interchanges" conecting to high capacity local access roads feeding the immediate area around South Shore Plaza, Crown Colony Office Park and Quincy Adams T Station
2) several dedicated lanes heading to I-595 bound for Rt-24 and I-95 South
3) Similar dedicated express lanes with their own interchanges for the through traffic to I-93 to Plymouth
4) dedicated lanes for the local connections at the first few existing interchanges of Rt-3
I-595?
That's the first I've heard of this.
What road becomes 595?
That's the would-be interstate designation for I-93 Braintree-Canton if 93 were re-routed down Route 3 to the Sagamore. Must be an odd-numbered prefix because it only touches an I-x95 in one direction, and 5 is the next available odd.
Quick related question: What would be required to upgrade rt 24 to an interstate?
Even-number prefixes don't need to reconnect to the parent, just another Interstate, like how I-290 connects I-90/I-395/I-495. It really ought to be I-695 (or, alternatively, an I-x93 designation given a new I-93 alignment along Route 3).
Why not just reroute I-95 into Boston and rebrand 128 as 695? It makes more sense for the spur interstate designation to be applied to a beltway, IMO. Then you can attach 595 to MA-3.
I don't think anything would actually be needed to turn the MA-24 corridor into I-193 except a rebannering.
The real obstacle would be RI-24, which is only partially built as a freeway and has wonky exits.
e: Wait, no, I forgot about the screwy 24/195 interchange. That shit probably can't fly if 24 was/is to be given an interstate designation. You might be able to get away with just designating everything between 93 and 195 as an interstate, though.
Not bad!
-I love the idea of 93/95 through Boston. That has always made infinitely more sense to me than routing the East Coast's most important route around the city.
-I'm not sure if I see US 6 along the Cape being upgraded to Interstate standards - lots of work to be done with substandard ramps, nonexistent breakdown lanes and, of course, the threat of overdeveloping/commercializing the Cape. Ending I-93 at the Sagamore would probably be sufficient considering 3 is already basically up to Interstate standards as it is.
-I'd designate 24 as I-695 as it would connect I-95 to I-195 in Fall River. Similarly, I'd redesignate I-193 as I-895 because it connects to I-95 on both ends as the official inner bypass of Boston. And just to be consistent without other designations planned, swap I-795 for I-595 (though I guess you could use I-595 for MA-2 or US-1 as well).
24 south of 195 isn't under consideration because of the truncated RI portion. All proposals from the last 30+ years active or bandied about only sought interstate designation for the 128-to-195 segment, which is all expressway. 24 into RI would've remained as a different route, which it kinda is anyway since nobody really treats the disconnected ends + 195 concurrency as a single road. So it'd be x95 with reset exit numbering from Westport north to 128.
The most deficient parts of the highway are the 2-lane 495-to-140 stretch + 140 interchange, the dangerous ramp splits with Route 79, and the 195 interchange. None of them are blockers to seeking the designation, but the feds are known to throw those in the circular file when they're unimpressed with road conditions so it's generally assumed that those 3 trouble spots will get settled up before an application gets filed. I think everything else is up to spec except a couple overpasses slightly less than the regulation 16' clearance and maybe a couple tightish ramps of little consequence. Generally speaking it's more "compliant" an expressway than anything in the Boston area save for those 3 aforementioned interchanges.
Note: The state has no say whatsoever in what number actually gets doled out. 29 years ago both CT and MA had the sign shops ready and waiting to stick 290 shields up the whole length of Route 52 from the Mass Pike to New London. But the USDOT had other ideas and surprised both states by handing out a 395 designation instead. Even CT didn't want that, the Worcester-area expressway layout and "395 ends, 290 begins" signs don't make sense to this day, and everyone went home feeling confused and unsatisfied. But thems the breaks when it comes to 3-digit interstates. No control over the name = spares a lot of silly cripple fights with local pols over vanity numbers (obviously a 2-digit highway like 93 is a different deal altogether if MA applies to re-route it on 3 to Bourne).
Braintree-Canton and 24 are each going to be x95's, anyway. And I don't think anyone here has got money riding on a 5- or 6- prefix enough to care what it's ultimately called. In fact, I predict that any x95 Canton-Braintree designation will just redouble people's efforts to call it "Route 128" once and for all, to the point where the state--finally--has to cave to irrepressible public will and put up x95/128 signs on it.
