Not bad!
-I'm not sure if I see US 6 along the Cape being upgraded to Interstate standards - lots of work to be done with substandard ramps, nonexistent breakdown lanes and, of course, the threat of overdeveloping/commercializing the Cape. Ending I-93 at the Sagamore would probably be sufficient considering 3 is already basically up to Interstate standards as it is.
Yeah, and the feds might quibble with a N/S highway taking on that many E/W add-on miles. You can get away with that (see 95 "North" on the CT shoreline) where the prevailing traffic between control cities is ultimately headed in that direction (i.e. NYC/NH-->PRV/BOS), but how do you decide that for Cape travel? You travel E/W across the Cape to/from...a split plurality going north on 3 and a split plurality going west on 6/195, but no clear-defined alpha dog. And the feds will concern troll that nitpick before we even get around to the part in Brewster where "93 South" is going north--due north after awhile--to the highway's terminus.
The only interstate you're getting on the Mid-Cape Highway is an E/W one fed via the oft-proposed/never-built southside connector and 25, either in form of an extended 195. Or (very longshot) a 2-digit I-82 taking over 195 and 6...the original-original candidate designation for the Mid-Cape and 195 when they were served up as a Hartford-Providence-Cape expressway thru-running from what's now I-84 and I-384. 93's never going to reach across the Sagamore. To the Sagamore...that's long overdue.
6 isn't that far off from Interstate standards. Yes, the Super-2 portion after Exit 9 has to be widened into a full-fledged 4-lane expressway. At least as far as Exit 11/Route 137, and for safety reasons even moreso than traffic reasons. But the existing 4-laner was originally earmarked for the interstate system when first planned so would only need some of the typical refresher work on outdated sightlines, shoulder space, and over-tight ramps/merges that every highway in the state has gotten. There's no blockers west of Exit 9 on the current road.
