The traffic engineers hate this so maybe its OK?The exact correct course of action is whatever the traffic engineers strongly discourage.
But they’d really really hate the appropriate and cost-effective solution: to demolish the overpass and replace it with nothing.The traffic engineers hate this so maybe its OK?
As long as the Bowker overpass remains in place, the traffic engineers are happy.The traffic engineers hate this so maybe its OK?
I like to look a bit differently at these types of transportation issues. The way I look at it is: what if the Bowker overpass had never been built in the first place? That is an entirely possible scenario. It was built at the same time as the Mass Pike extension, not formally a part of that project, but as a direct result. At the time in the early 1960s, the Charlesgate road bridge over the railroad had to be replaced due to the Pike construction, so that provided an opportunity to add the overpass as an extension of that new bridge. I"m guessing if the Pike had not been built, then there never would have been a Bowker overpass. At the time, a real debate was raging about whether or not to terminate the Pike coming in from the west at Allston in anticipation of the planned tie in to the (subsequently cancelled) Inner Belt Expressway. My point is, if the Bowker had not been built, then traffic would have never known the difference, and would have dealt one way or another with the Bowker's non-existence. So, why not eliminate it now and allow traffic to adjust accordingly. In an alternative history, it may never have been built anyway.
Just staring at the map I can't help but think something at grade could work utilizing the existing Charlesgate East and West roads - thinking of West taking traffic into Kenmore/Fenway, east taking traffic out of them, and extending both into two smaller Pike/Ipswitch crossings that can then interface into Boylston St. Would lose a bit of park here, but, would that not be worth getting rid of the overpass entirely? Will admit CG West seems the easier fit, with CG East being a bit more shoehorned into a Bolyston St connection. I don't see how this would work any worse than say the Forest Hills overpass removal provided intersection crossing and lights are intelligently designed and timed.
I’m confused here. 1) Is all of this a done deal (seems like a shitload of major changes to be done with little or no fanfare in the globe etc) and 2) I still can’t figure out what they’re doing here: the diagram seems to showLooks like this is going to happen, with the state committing $179 million to the project. It will include replacement of the viaduct, eliminating the Charlesgate East connection, major landscaping and Muddy River daylighting, elevating Storrow Westbound to cross the river, a pedestrian path connecting the two sections of Newbury St., and a parallel to Bowker "green bridge" for pedestrian, bike, and other kinetic human connection between the Fens and the Charles Esplinade.
Details here: https://news.northeastern.edu/2022/10/04/charlesgate-park/
h/t UniversalHub
The point I was trying to make is: just because a road facility exists, doesn't mean it is immutable and must remain in place. Yes, it's been there since the early 60, and yes, motorists love it, but does that seal it's immortality? San Francisco tore down two major and lengthy elevated highways (the Embarcadero Freeway and the Central Freeway) and replaced them with surface boulevards. Did that lead to carmeggedon? No. People adjusted, traffic is fine, even though there were no new transit facilities built to replace the capacity of these freeways. If San Francisco can do it, I think it can be done here.This doesn't feel like a particularly useful perspective to me. You could seemingly apply this logic to every piece of infrastructure - "if it was never built we'd just have had to deal with it not existing in some way" - well, yes, that's true.
That doesn't really address anything about the utility/value of the piece of infrastructure or seem to inform any sort of decision-making about it.
Gridlocking these intersections would be a good thing. Slowing cars down is a good thing. Reducing the "LOS" is a good thing. It makes the city safer and it discourages automobile use.This is absolutely a valid point.
That remains to be seen. It's absolutely true that changes can be made without causing disaster, or lesser but still problematic (unintended) consequences. Pointing to anecdotes from other cities might well be sufficient to rebut any "we can never change anything" kinds of arguments (given that those are reflexive-reactionary in nature and typically weak arguments anyway), but it does not support any further conclusions about the specific impact of specific projects and proposed changes. The fact remains that we do not live in the alternate history where these pieces of infrastructure were never built, and as such the existing traffic and commute patterns are shaped by and around the existing infrastructure. It's absolutely valid to propose that changes (such as elimination of the overpass) can be implemented without problematic consequences elsewhere, but it requires evidence and analysis for that argument to carry the day. "The traffic will adapt" is, intuitively, true in a technical sense, but if it "adapts" by gridlocking every intersection around Kenmore, I don't think many people will be pleased at that "adaptation". So, by all means, advocate against the reflexive "must keep things the same" mindset, and examples from other cities of changes that didn't cause havoc are good evidence that we may be able to accomplish the same, but it's also true that just because we can get rid of a road facility doesn't mean that we must remove it either.
This discussion reminds me of something I read a long time ago, probably in the 1960s, in which Los Angeles traffic engineers were complaining about the existence of pedestrian crossings, and how those made it harder to perfect their traffic models and enable smooth flowing traffic. This situation with the Bowker seems to all boil down to priorities: what's more important, smooth flowing traffic or the continuity of the Emerald Necklace park system and a more natural Muddy River and environs?Gridlocking these intersections would be a good thing. Slowing cars down is a good thing. Reducing the "LOS" is a good thing. It makes the city safer and it discourages automobile use.
at a critical traffic point to the city's main hospitals, I'd say ambulances sitting in gridlock traffic would not be a good thing.Gridlocking these intersections would be a good thing. Slowing cars down is a good thing. Reducing the "LOS" is a good thing. It makes the city safer and it discourages automobile use.
Do ambulances drive over the Bowker often? I don’t think I’ve ever seen one there.
It really doesn't matter - free movement of emergency vehicles in general is kind of required for a city to be safe.
Agreed, but it’s not like there isn’t gridlock in other parts of the city that could impede emergency vehicles.
The other post specifically called out this stretch as being very important for vehicles driving to Longwood. Based on my own experience, I don’t think that’s true.
If this were actually a priority (it isn't) the city could just take one line in each direction as emergency vehicles only and set up cameras to capture and fine each lawbreaker. If the state has a problem, they can sue.It really doesn't matter - free movement of emergency vehicles in general is kind of required for a city to be safe.
You'd have one day of gridlock and then people would learn that they can swing their two legs to locomote themselves.Fair, but the original proposal called for intentionally gridlocking the city, preventing the movement of people and goods (and emergency vehicles) so as to punish people for traveling beyond several blocks from their homes. It got a positive response.
