Downburst
- Jul 20, 2012
I can't think of any other urban neighborhood in the US that has something like it.
Perhaps there's a reason for that.
This was my concern too. These lifts don't usually come to a complete stop. They move slowly through the loading/unloading area and you have to step into it while it's moving. I don't know how that would work here. If you stop them completely, those 9 second headways are even more of a leap. I rode the system in CDMX two weeks ago for fun and it was definitely not ADA complaint (consistently moving, uneven platforms, etc.). Then again, the doors open on the Metro there before the train even stops in the station so I don't think it's as much of a concern there.
In regards to the ADA compliance, the Roosevelt Island Tram doesn't loop. It has two large cars servicing two terminal stations - not multiple stations.
The Mexico City one IS wheelchair compatible (ADA is just a US law).
However, its like getting a wheelchair on a bus. Instead of loading in 5 seconds, it takes a minute while the driver lowers the bus, deploys the ramp, raises the folding seats, and attaches the wheelchair to the belts.
Commuter rail is similar. The conductor has to walk to the cabinet with the wheelchair ramp, unlock it, carry it over, place it, and then return it.
So yeah, if someone in a wheelchair wants to get on, everybody has to wait while the stop the gondola. Mexicable has level boarding, so its not a long process.
And it's so rare, it doesn't impact normal operations.
BTW: Disney is building a new aerial gondola system instead of extending their monorail. They obviously will comply with full ADA. And while its not a city, Disney takes moving people quickly VERY seriously.
Since I haven't ridden it since it opened is the Silver Line not successful or is it that there's too much demand for it to handle?
The SL is absolutely slammed with passengers. You sometimes need to wait in the station for multiple busses to come through before you can find space to board.
This could be fixed by simply running shorter headways. There are a whole bunch of free (#FreeTheRamp) to close-to-free (better signal priority) to relatively cheap (buy more purely electric busses for the tunnel portion) to relatively more expensive (electrify the entire SL2, tunnel under D) ways this could be done. And all could probably be done for under the $100 million cost of the gondola.
Nobody rides it, it's too crowded
Heres an active gondola station in Texas. Capacity is 5,000 per hour
https://www.youtube.com/watch?v=HSlH3yoqTO4
It's also worth pointing out that Roosevelt Island is also served by the subway. The tram is useful if you live on the island and work in midtown, so basically from one terminal to the other. The tram was built before the subway and is still used but the subway handles way more traffic.
There used to be a trolley that ran across the Queensboro Bridge right there and it stopped on the bridge at an elevator so riders could reach the island. Had the trolley not been removed the gondola wouldn't have been built in the first place.
Man, you could time that thing with an hourglass.
How do they get around ADA non-compliance since it looks like it doesn't fully stop at the station?
It's not actually a straight line at all if you look at a map, and there's tall buildings on both sides. I'm pretty sure Winter St is simply too narrow. One huge drawback to gondolas is they can't turn corners except at stations, and the stations are the big expensive part. (You can bend the line a couple degrees at towers by tilting the sheaves that the haul rope runs over.) Oh, and good luck getting approval to put a gondola terminal on Boston Common.
It actually is pretty straight, all told. Winter Street might be narrow but probably isn't too narrow to accommodate this. The terminus at Park Street - I agree - that would take some major political capital to score, given the historic area.
