- Dec 10, 2011
I'm posting this here just because it is hard to find the "original" CLF settlement that kicked off 3 decades of transit work in Boston. Recall that in the final hours of the Dukakis Administration, the State and the CLF cut a deal for transit offsets--essentially cutting a "friendly" deal with the Dukakis Admin rather than risk having to negotiate with the incoming Governor Weld.
While not the settlement agreement (please post if you have access) what I've reproduced below is what was later enacted as 310 CMR. I'm just quoting the "project list" part. Other sections in the PDF include provisions for filing support documents and provisions for substituting other projects.
I believe the list below is actually modified from the original, and this is hinted at by a provision (in section 8) that says:
7.36: U Transit System Improvements
My bolding added implies both that the original deal included Arborway and Red-Blue, and also that, while the original deal was GLX to "Medford Hillside" (see end of quote below) by the time this provision was added, they knew that GLX terminus was more specifically in the Ball Square/Tufts U area.1. Calculating the NMHC, CO, and NOx emission reductions that would have been achieved by completion of each of the following projects, using latest planning assumptions and latest air quality emission models: the Green Line Arborway Restoration; the Blue Line Connection from Bowdoin Station to the Red Line at Charles Station; and the Green Line Extension to Ball Square/Tufts University;
(2) Transit System Improvement Projects. MassDOT shall plan and construct and render available for public use, transit system improvement projects including the following projects in accordance with the schedules and requirements set forth in 310 CMR 7.36:
(a) Before December 31, 1992 construction of the following facilities shall be completed and opened to full public use:
1. Lynn Central Square Station and Parking Garage
2. North Station high platforms and new tracks
3. Lynn Transit Station Bus Terminal
(b) Before December 31, 1994 construction of the following facilities shall be completed and opened to full public use:
1. South Station Bus Terminal
2. South Station Track #12
3. Ipswich Commuter Rail Line extension to Newburyport
(c) Before December 31, 1996 construction of the following facilities shall be complete and opened to full public use:
1. Old Colony Commuter Rail Line Extensions to Middleboro and Plymouth
2. Framingham Commuter Rail line extension to Worcester
3. 10,000 Park and Ride and Commuter Rail Station parking spaces system-wide outside of the Boston core area as defined by a report to be submitted to the Department by MassDOT which identifies the location, size and market area of each facility constructed to satisfy this requirement. Said report will be submitted three months prior to the deadline for this project. 310 CMR 7.36
(d) Before December 31, 1999 construction of the following facilities shall be completed and opened to full public use: 10,000 Park and Ride and Commuter Rail Station Parking spaces system-wide outside of the Boston Core Area in addition to those spaces developed pursuant to 310 CMR 7.36(2)(c)3. as defined by a report to be submitted to the Department by MassDOT which identifies the location, size and market area of each facility constructed to satisfy this requirement. Said report shall be submitted three months prior to the deadline for this project.
(e) Before December 31, 2001 construction of the following facility shall be completed and opened to full public use: South Boston Piers Electric Bus Service [NOTE: later known as the Silver Line Tunnel]
(f) Before December 31, 2007, construction of the following facility shall be completed and opened to full public use: Old Colony Commuter Rail Line Extension to Scituate (Greenbush).
(g) Before December 31, 2008, construction of the following facility shall be completed and opened to full public use: Blue Line Platform Lengthening and Modernization.
(h) Before December 31, 2011, construction of the following facilities shall be completed and opened to full public use:
1. Fairmount Line improvements consisting of enhancements of existing stations including, without limitation: platform extensions; improved lighting and improved access; a new station in the general location of Four Corners, and a new station in each of the neighborhoods of Dorchester, Mattapan and Roxbury; and bridge upgrades and other measures to improve service and increase ridership (the Fairmount Line project). MassDOT shall meet the following interim deadlines for the Fairmount Line Project:
a. One year from the effective date of 310 CMR 7.36, develop a Request for Proposals for a design consultant, complete the competitive procurement process, and issue a notice to proceed for a design consultant; and
b. Within two years following completion of the requirements of 310 CMR 7.36(2)(h)1.a., complete the requirements of 310 CMR 7.36(3)(e)1. through 6. and 310 CMR 7.36(3)(f). 310 CMR 7.36
2. 1000 new park and ride parking spaces serving commuter transit facilities, in addition to those required by 310 CMR 7.36(2)(c)3. and (d), within the 101 cities and towns constituting the Boston Metropolitan Planning Organization.
(i) Before December 31, 2014, construction of the following facilities shall be completed and opened to full public use:
1. The Green Line Extension from Lechmere Station to Medford Hillside; and
2. The Green Line Union Square spur of the Green Line Extension to Medford Hillside.
