I don't see how anything would get better unless somethings were pushed underground or you create an 'El'. The Boston College "B" line runs down the center of Comm. Ave. That alone plus the lanes on the either side make it feel like you're crossing a HUGE expense of roadway (punctuated by rails in the middle).
This location is multi-level. the Mass Pike is under there and the Mass Pike leads onto an overpass at that same relative spot above the Grand Junction railroad tracks.
So you have Comm. Ave, above the Mass. Pike+Storrow Drive, and also above the Grand Junction rail yard / Commuter Rail. 10 lanes it-is, unless you have a plan to get some elements out of that junction. With all of these things converging there it means you have to start further away to begin to move things on different grading and that increases costs.
It appears that a few different designs have been thrown around. But there's a few light cycles that have to be implemented there as well.
Commonwealth Avenue Bridge (Boston, MA) - VISSIM Simulation
https://www.youtube.com/watch?v=2fmEfwf4Cro
That simulation is so inaccurate. Pedestrians are acutally stopping at the do not walk sign. That doesn't happen in Boston.
I think someone mentioned it in a different thread, but people don't follow walk signals because most engineers don't time signals "properly". They are timed to provide flexibility and efficiency for vehicular traffic, while pedestrians are given the bare minimum. This sort of makes sense because cars cause gridlock, but no one really notices a huge queue of bikes or peds. It doesn't create widespread access issues.
Anyway, for example, 7 seconds is the min walk time, so typically they will always get that, and just that. The sooner the signal goes to don't walk, the more "flex time" they have available to have the vehicular signals respond to the current traffic volumes. This usually means people are waiting to cross the street when it is perfectly safe to walk.... so why not cross "illegally"?
As someone who designs these for a living, this is false.
The walk interval (solid white pedestrian indication shown) is an absolute minimum of 7 seconds. To that, we add a calculated pedestrian clearance time which assumes a pedestrian is about to enter the crosswalk and grants sufficient time for them to make it through (the flashing orange hand phase) before the hand indication turns to a steady orange. And on top of that we add a 3 or 4 second buffer before the vehicle phase kicks in to ensure all pedestrians are clear.
And on top of that, the calculations are predicated on a minimum 3.5 ft/s walk speed, which can be lengthened when you consider external factors such as if the crossing is used by elderly people or if there is a high number of pedestrians concentrated there at a particular time.
Looks like they are going to have all the new beams in place by the end of the day today.
Too soon to speculate that they might re-open the pike ahead of schedule?
https://app.oxblue.com/open/BU/bridgedeck
Does the MBTA usually use charter busses for replacement service? I've never seen that before when Red is closed north of Harvard.
Baker & his cronies are obsessed with contracting everything for the T out to private bidders because PPPs are magic. Under Baker, the T can't do anything on its own. The transit service isn't allowed to be a transit service.
Peter Pan & Paul Revere are providing bustitution services for this contract. PP is using their high level buses and PR is using some transit-style buses.
Honestly, it's probably because the T doesn't have enough spare buses during rush hour...
The T literally just finished receiving their 375 new buses in July, which are intended to be 1-for-1 replacements. They could have used plenty of the old buses that were still in fine working order to provide the bustitution.
Here are some photos from this past weekend:
Approaching from Agganis - the number of people confused by this sign was astounding.
New bridge supports arriving by truck:
One big support parked on the Pike. Note that inbound traffic is down to a single lane. I also assume that the tolls were set up to either ignore the inbound traffic or to play nice with the traffic heading in the opposite direction of the 'primary' camera.
The construction zone.
