The only thing you have to put way out there is an LNG pumping station with associated pipelines. For the exact same reason that same thing has been proposed before: keep the terrorism targets out of the inner harbor and out from under the Tobin. Fuel tankers come in every day to Global Petroleum in Eastie. Don't think they've ever had a major spill on the Chelsea River despite that tank farm being there for close to 70 years.
Tanks leaking underground is a bad thing. Same reason home heating oil tanks are no longer allowed to be buried...you don't know they're leaking until the damage is done. Underground leaks even worse when the ground is saturated by water. Above-ground tank farms are the safest. Paint them pretty colors if they're unsightly, but that's kind of the best way to do it.
We don't have a large enough seaport for the floor barrier to be all that big a restriction. This isn't Halifax. Pretty much the biggest ships that come in here are the cruise ships. Harbor could stand to be dredged a little, but we're not exactly going to be getting a lot of PanMax ships at Conley Terminal.
