- May 25, 2006
Continuing from the conversation in the Red/Blue thread I sketched out some possible Blue Line West routes.
https://www.google.com/maps/@42.365...=!4m2!6m1!1sz-XOBJKktHNs.k7_rfjEEWk5I!5m1!1e2
(If this map doesn't load for people tell me and I'll make it an image)
There are three possible routes. All start at Bowdoin and head to Charles/MGH, run under the Charles River to Binney St.
- The northern route runs west from Binney St to Central Sq under Broadway and Prospect St. After Central it travels under Western Ave straight across Allston to Arsenal St in Watertown. From here it's a straight shot under Arsenal to Watertown Center.
- The middle route runs to Central Sq as described above but then runs under River St and then Cambridge St to Union Sq in Allston Center. From here it runs west under North Beacon St to the Arsenal Mall and on to Watertown Center via Arsenal St.
- The southern route would run along Vassar St after Binney and along the Grand Junction to West Station. After West it would run under Lincoln St along the Pike to the Arsenal Mall and on to Watertown Center.
Each route has major pros and cons. The first two would run through the densest residential areas and connect to the Red Line at Central which would convert much of the bus traffic coming from Watertown and Allston. These routes would also require the most tunneling and be much more expensive.
The Grand Junction route would be cheaper as it could run above ground after Mass Ave to West Station. While it wouldn't connect with the Red Line until Charles/MGH it would better distribute passengers around Kendall Sq. It would serve more job/tech/education centers then the two other routes which would make it more useful for commuters coming from Boston or Logan and transferring to the Blue Line.
While the Western Ave route would certainly help the Harvard-Allston area grow and take many commuters off buses I think a route that runs more south could do the same (if extended to Watertown) while also taking pressure off the B and 57 bus.
