...and here's the quick-and-dirty MS Paint drawing of what I described. Big, so enlarge it.
Legend:
NO MONEYBACK GUARANTEE: This is NOT studied anywhere near as well as the Marginal St.-east routing is, where the slip-under of the Orange Line was studied in the 70's for Washington St. LRT replacement. So no guarantees that the BBY connector won't take on cost bloat between Clarendon and the old tunnel interface @ Prudential for additional side-wall reinforcement of the air rights pegs. It should be completely structurally feasible because of the subway tunnel's narrower footprint than the air rights pegs straddling the wider Worcester ROW and lack of any structures or utilities underneath the Worcester trackbed. Very low odds of there being any fatal engineering blockers because this follows the golden rule of staying within boundaries of cleanroomed urban renewal transit infrastructure. It's the potential cost bloaters from engineering mitigation that are complete unknowns until a full DEIR gets done.
You can definitely build it...but it's impossible to guess today for how much $$$.
- Dashed lines are tunnel segments, solid lines are surface segments.
- Line thickness = 3 pixels per track (i.e. 4-track Tremont tunnel > 3-track NEC > 2-track all else).
- Dark green is existing Green Line, light green is new construction. Orange is Orange, purple is CR. NOTE: Purple is hard to see where new Green tunnel underpins Worcester Line, but it's there.
- Yellow boxes are station platforms.
- Points of interest are lettered. See legend below.
- Pike outline + ramps filled in with paint bucket under Pru to highlight. NOTE: This screencap doesn't show the Pike-to-Huntington WB ramp very well; it's right next to Prudential Station behind the letter "R".
- All of the South Station and Washington St. branch infrastructure out-of-view is identical to stuff previously covered on the Reimagining Green thread. Reference any of the MS Paint renders there.
Legend:
A. Existing 4-track Tremont tunnel w/flyovers, giving way to new 4-track tunnel extension to corner of Tremont/Marginal.
B. Tufts Station. 2 island platforms. Track layout: BBY outbound--BBY inbound; SS/Washington outbound--SS/Washington inbound. Down-and-over ped walkway to Orange Line fare lobby (out-of-view) not shown. Daylighted headhouse directly above in park.
C + D + E. "Tremont Jct.":
F. SS/Washington tunnel duck-under of Orange Line tunnel.
G. Washington Branch at-grade split. (Herald St. portal not shown; see GL Reconfig thread for details.)
H. Orange Line portal (existing).
I. New tunnel to BBY. Under Marginal St. to Columbus behind Pike retaining wall (same as the SS tunnel east on Marginal). Cross diagonal under Pike (same as the Washington portal tunnel). Then slip under Worcester tracks into BBY Station.
Worcester Line + BBY Worcester platform must be temp shut down for duration of construction, service re-routed to North Station. Augment inside 128 with buses, expanded D Line frequencies, Yawkey shuttles best as possible during shutdown and ration limited Grand Junction/North Station capacity for Worcester/MetroWest thru trains.
J + K + L + M. Back Bay Station platforms. . .
O. Existing Central Subway, Copley Station, Copley Jct. (stet)
P. Turn off Worcester Line @ Huntington Ave., go down Huntington. Structural underpinning of side wall required when turning off Worcester footprint. Pike ramp to Huntington *should* be far enough upstairs to have no structural impacts, since existing Huntington tunnel passes below in same spot. (Needs verification, but at worst possible case ramp could be shut for 1-2 weeks while shivving in 1 support beam underneath.)
Q. Merge into old Huntington tunnel at-grade, roughly at point where it straightens out before the Prudential platform. Retain Copley Jct. tunnel for emergencies and alt routings.
R. Existing Prudential platform (stet).
--------------------------------------------------B. Tufts Station. 2 island platforms. Track layout: BBY outbound--BBY inbound; SS/Washington outbound--SS/Washington inbound. Down-and-over ped walkway to Orange Line fare lobby (out-of-view) not shown. Daylighted headhouse directly above in park.
C. SS/Washington tracks diverge east.
D. BBY tracks diverge west.
E. Wye track connects the two for thru-routing.
If building any one leg of this network first in isolation, make sure Tufts + the 4-track tunnel extension + the hollowed-out space for the junction are pre-provisioned. Do this even if the other diverging track berths and wye area are left vacant for 20 years until the next funding installment.D. BBY tracks diverge west.
J. Worcester Line (existing). Closed and disrupted during GL tunnel construction, put back together after. Green Line level built as shallow box tunnel directly under Worcester platforms, with tunnel roof forming new trackbed/floor of Worcester level.
K. Green Line (new). Shallow-level below Worcester tracks. Accessible from Orange platforms inside fare control by going down-and-over from Orange platform (Orange is on other side of wall from Worcester, Green directly under Worcester).
L. Orange Line (existing). No modification except for grafting down-and-over corridors onto egresses for Green Line level.
M. NEC (existing). Stet.
N. GL tunnel under Worcester Line. Shallow box tunnel, roof is Worcester trackbed. Slotted between air rights pegs because GL tunnel narrower than Worcester trackbed. Maximum possible structural impacts would involve side reinforcements along tunnel roof (arched roof?) closest to existing air rights pegs, but otherwise stays entirely within-footprint and shouldn't be any concern for fatal blockers.K. Green Line (new). Shallow-level below Worcester tracks. Accessible from Orange platforms inside fare control by going down-and-over from Orange platform (Orange is on other side of wall from Worcester, Green directly under Worcester).
