You did:
I did no such thing. I said beside-adjacent, next to
You're going to put a trolley through a highway interchange rotary??? Remember how well that worked out for the A-Line at Newton Corner??? Gone within 4 years of the Pike's opening.
Not through, beside. there is enough room on the west side of the Medford rotary to get the tracks to Joan’s? Hair salon. Ideally, take that one house for a terminus.
This is not your great grandpappy's Fellsway:
https://youtu.be/WesgTvAkMOE.
A 10 ft. median is not going to host a trolley reservation. You would have to squeeze the shoulders as tight as
Huntington Ave. to regain clearance for a reservation...on a MassHighway-managed parkway, not a city street. So this roundabout diversion very much suffers from traffic effects if you don't get every last bit of that reservation space forked over. If you have to do any amount of street-running, even semi-separated to the left of the yellow stripe, it's going to dramatically slow down the trip.
The Fellsway is 95 ft wide. And if that isn’t enough, there is 5-6 ft of grass on each side before you hit the sidewalk
Then there's the illogic of >3.5 miles north, west, and south out of Wellington to reach a destination that's 2 miles due west of Wellington via Route 16.
That's...awful transit.
Except Google Maps puts it at 3 miles and 16 min on the bus. On Saturday. At 3pm.
In what universe does a transit trip require you to swing closer to the Middlesex Fells to get between two destinations that are on the Mystic River? The 95, 101, 103, and 134 can somehow get between Orange and Medford Sq. without knotting themselves like a pretzel and going miles out of the way.
again, .5 miles and hella less than 16 min. AND, no need to get off the bus, walk up the ramp,and wait for the next train at Wellington.
If that can't be done with another mode, maybe there's a big problem with the mode selection. People are going to notice that they're running around in circles. They don't like it on the bus routes that do it; they won't like it on a so-called rapid transit line, either.
An arc , yes. But hardly circles. And at least 10 min faster to Haymarket
Why are you bringing up the 111? It's far from either of your proposals.
So, taking 800-1000 cars off Rt 1 in Revere will have no impact on Rt 1 on the Tobin?
But here's one problem the as-planned UR does solve: it hits that bus square in the middle and serves up transfers to Orange and Blue 1-2 mi. / 2-3 stops in each direction from the Chelsea transfer, as well as run-thru options on Green. That's the UR in a nutshell: quick-hit transfers from intercepted Key Routes. That's useful.
Another straw man. They are not mutually exclusive. In fact,any people using Saugus or Medford who are going to Kendall or Allston can switch at Sullivan, which could obviate the need for a station at the intersection of UR and The DE line.
Between Malden Ctr. and Linden Sq. the Saugus Branch duplicates but never touches the 106, 108, 411, 430 from 500-1250 ft. away, and small portions of the 105 and 109 also without a touch until Linden. You're not scooping up transfers or bringing multimodal value-addeds that way.
So you MODIFY THE BUS ROUTES!
There are many, many issues with the route...because being too askew from traffic signals to coordinate phases and queues is a recipe for congestion. Now multiply that out by the number of crossings with that characteristic, and it's a problem.
In your opinion. I disagree.
Lest we forget, what you are asking for here are the FIFTH and SIXTH northern branches of the Green Line: Medford, Union, Urban Ring Cambridge (branch off Union), Urban Ring Chelsea, the Fellsway loop-de-loop, and Saugus Branch. The latter two predicated on Orange Line to Reading as build requirements, and tearing apart part of Orange from Sullivan to past Wellington.
Tearing apart? You mean actually using the third OL track and the CR rail?
So UR runs from West Station to Sullivan. It shares the line with Saugus and Medford(3 lines)
Saugus and Medford share Lechmere to North Station with D&E(4 lines) The Central Subway handles that every day. And B,C,and D run every 6 min and E every 9. I would suggest that Saugus and Medford run every 9 like the E. That would be 4.5trains every 9 min instead of the 5.5 trains every 9 the Central Subway sees
This is more than Kenmore fed at its busiest-ever when the D and A coexisted, and the conditions put on the Orange Line for the build are untenable for planning purposes.
Not even a clue of what your point is here. If you are talking about getting the GL from west of Sullivan to east of Assembly, how do you expect to get to Sullivan from Chelsea? Airlift? No, by getting GL over/under OL somewhere between Sullivan and Assembly.
Even with the two UR branches trading off thru-radial routings with Lechmere-inbound routings for service variety, that's an extreme amount of traffic to be dispatching out of the north end.
The Urban Ring should not be at Lechmere.
To have two of those branches addled by many mixed-traffic impacts is going to make for frustrating delays when a blown schedule hits Brickbottom Jct. And it'll drag down the other branches with grade separation as an unintended effect. The Kenmore end is not going to attempt to saddle itself with more unless the subway gets extended to BU Bridge for that Urban Ring hook-in,
Again my earlier comments suggested Saugus and Medford come after Urban Ring. I also assume that one of them might turn around at Gov Center.
and a surface D-to-E connection allows for some fileting of load-bearing short-turn service so they can work in Needham without hiccups.
Also, no disagreement
Brickbottom Jct. is getting built plenty robustly for GLX and the future Ring appendages, but it's got its limits. Six north branches is well past the limit.
Again, no track sees 6 branches, and I think calling the UR TWO branches is disengenous.
Transforming the Green Line doesn't involve adding more B Lines. It's not in the business of replacing bus routes that could be tuned. The future involves more interconnects, more radial paths around downtown, more touches that
enhance buses at node points, more fluidity. Not a return to the 1920's with more linear streetcar routes because streetcar = kewl.
