The Fitchburg was historically quad-track out to the West Cambridge freight yard (reason why they were able to do GLX-Union pretty easily), and tri-track from West Cambridge to the split with the Central Mass after Beaver St. in Waltham because the Central Mass used to have its own running track along the Fitchburg ROW (residue from when it was a competing RR). Through Belmont Center station it's quad-width because the Central Mass leased a blank spot for an expansion track that never came. So you'd have no issues getting to Belmont Center, though I would assume GLX would outright be eating the station instead of side-by-sideing a superstation (a little too much width).Would it ever be possible to run a GLX to Belmont Center and preserve the commuter rail as well? I’m guessing the ROW just isn’t wide enough, right?
Past Belmont Ctr. (if the eventual goal is a GLX-Waltham) the ROW narrows down to tri-track along Pleasant St., though embankment reshaping can easily add the 4th berth. Waverley station is a 1955 grade crossing elimination so it was only ever provisioned as double-track; would need some substantial retaining wall and bridge work to quad-up, but is feasible because the station really isn't abutted by anything within the square except its own parking lot. Past there it's back to tri-width with embankments that can be traded for retaining walls. And then you'd have to swap the Fitchburg mainline to the Central Mass out to 128 to free up the Waltham Center-Brandeis tracks for GLX because that definitely was only double-track and has some dense abutters. It'd be less of a megaproject than GLX-Medford was widening a historically 2-track ROW, but probably isn't anyone's idea of a top priority because :15 Urban Rail service to 128 is probably worth a generation's worth of growth absorption.
