That's really interesting to see... though I don't understand how they'd connect to the existing Boylston Street Subway, especially since back then the Boylston Street Portal was still in use.
The connection was going to be in the same area as the old Boylston St. and Public Gardens portals. If you pass that area on an inbound train you see the right-side wall peel away. That was the provision for it.
I don't think it would've been accessible at all from downtown...strictly a Kenmore-Post Office Sq. shot. The provision isn't pointing in the right direction to reach downtown or cross over into the Boylston St. portal on the pre-1942 Huntington Ave. routing.
Interesting... if I was going to do this sort of thing today, I think I'd eschew a connection to Boylston Station altogether and just connect to Chinatown; I'm not sure how you could retrofit Boylston to be both a transfer station and have the ADA-required elevators... Arlington and Chinatown are probably close enough for most people.
Today, I'm pitching not for any line but for the railcars themselves:
  • All advertisements, posters, rollsigns, et cetera should be switched to tamper- and vandalism-resistant electronic signage. These could have various display phases, included 'targeted/local' advertising displayed only at the stations nearest to whatever is being advertised, as well as interactive/animated advertising (for a premium.) The existing line and system maps posters would be replaced with electronic equivalents capable of displaying where in the system your train is, and how tight or loose the timing any nearby transfers and connections will or will not be. Rollsigns would display the destination only, i.e. "To ALEWIFE" instead of the current "ASHMONT / ALEWIFE" setup. These could also be configured to switch upon doors opening to a countdown timer (for time to departure) or the name of the present station (i.e. At PARK STREET).
  • LED lights should replace the painted-on coloring for trains - a wide centerline stripe across the car, and a light border around the doors. (These could be configured for some kind of visual indicator of the time until departure, such as the color bar shrinking or the border around the doors draining away.)
  • Station platforms should feature a number of countdown clocks - the next few trains on the platform should be posted overhead, and 'time train has been in station' should be on a clock at the forward end of the platform. The Station Information signs which presently show system map, line map, and surrounding areas, shold change to be an interactive 'neighborhood map,' interactive system map, and interactive map of the station. All of these should allow riders to receive assistance in charting a course to their destination.
    • The interactive system map should always be placed in the center, and have an ancillary function of changing the neighborhood and station maps to display those of other stations.
Along the same line re: railcars and this being crazy transit pitches, I do think the T should eventually have their heavy rail all be the same stock. Just seems like it would be easier to only have to work on one type of vehicle rather than 3, and those orange line cars just feel like caves (the faux wood doesn't help much).
I apologize if this has already been discussed, but something I've always wondered, (though this falls under batshit insane transit ideas):
Would it be physically possible with the proper engineering to build an entirely new transit system 10-20 (50+?)feet below the current system? Obviously this is a financial impossibility but in a cost-no-object fantasy are there geological problems that even modern engineering wouldn't be able to work around?
Sure people will whine about have to descend that deep in the ground to catch a train, but is possible?
^ I've heard it's already there, but it's a closely guarded secret by those in the know.
Not really. Mechanically all 3 lines use more or less the same cars. The only difference is in the carbody size. And since the carbody is just a solid frame, that makes little difference for repairs. Parts, systems, etc...very much common. So much so that the new Orange and Red procurements are required to go to the same vendor. If Siemens were to win that bid, then all of Blue and Orange + half the Red fleet would essentially be 're-skinned' 0700's.
In the case of the Orange 01200's and now-retired Blue 0600's, they are literally the same vehicles built by the same vendor in the same factory on the same production run with only the slight length differences. Right down to being able to accept dual third rail + pantograph input...just slap an off-shelf pantograph on the roof of the 12's and they can run on overhead. And those cars are likewise literally the same make as the PATH PA3 cars retired last year. 24 of the 0600's, before the T determined the carbody rust was too great to rehab, were originally due to get overhauled and shipped to Orange where they'd trainline with the 01200's. There were internal jacks that could adjust the floor height to match the different-height Orange platforms, and then the only difference is that some Orange consists would've had shorter Blue cars mixed in as trade-off for more overall consists at tighter headways. As of now, because the Orange order was so badly delayed, they stripped the 0600's of all good-condition parts and stored them in a warehouse in the event of some funding nuclear winter where the 12's have to be band-aided together for another decade.
Red Line 01800's are almost identical to Toronto's T1 cars and the short-lived prototype run of NYC subway R110B's also built by Bombardier.
The only reason for having uniform carbodies is an interconnected system, which we don't have and have no feasible means of doing within the lifespan of any of the heavy rail cars currently in service. There's not much impetus to standardize beyond that because the guts of these cars are largely interchangeable...and literally so when it's the same builder re-skinning the same make. It's very unlike the trolleys which are customized to excess for Boston. Heavy rail is a much simpler and more standardized mode: common guts from the factory spit out with a different tincan on top. The T doesn't lug around any cost premium for buying different dimensions on those lines vs. Green, where they ALWAYS have to overpay for customization over off-shelf LRV's.
I believe thats what London did for the tube
[*]LED lights should replace the painted-on coloring for trains - a wide centerline stripe across the car, and a light border around the doors. (These could be configured for some kind of visual indicator of the time until departure, such as the color bar shrinking or the border around the doors draining away.)
This is an awesome idea. BART currently plans something not dissimilar from this, but I think the door outlines will simply blink for something like 10 seconds before the doors close. The draining away would work better on an automated system where the trains spend a set time in each station, since I assume trains leave when the operator determines boarding is complete.
Replacing the color of the train is something I've wanted for the T for a long time. I realize anything to do with paint schemes is pure personal taste, but I think the fully-colored cars are tacky and look like toys. The T should have 1 common scheme and subtle color accents.
As a combination of 2 of your ideas, you could have a LED stripe along the side of the train that both displays the color and the destination, and maybe a couple other landmark stations on the way. That's the way road signs work...
I'd try and avoid putting too many stations 'on display,' to avoid sending mixed messages and/or confusing tourists. (I know, I know, bear with me here...)
The two most important stations as far as indications are concerned are Next Stop and Last Stop. Having "NEXT STOP: ______ DESTINATION: _______" against a backdrop of the color of the line, possibly scrolling so that you don't have to copy it five times but everyone can still read it, should work great. A wide, large stripe against a polished chrome background would look great in my opinion, and the text wouldn't foul that up too badly. You could even take the messages away a second before the countdown on the doors runs out - with or without a message to the tune of DO NOT ATTEMPT TO BEAT THE CLOSING DOORS, revoking the display of such vital information would subliminally send or reinforce that message, 'I shouldn't try and get on this train because there's a very good chance the doors will get slammed on me.'
You know, I'd honestly like to see something like the bus rollsigns on the Green Line- they could go back to showing "via Beacon St." or whatever. (I suppose "Lechmere / via Subway" is probably unnecessary) Or at the very least not have to abbreviate everything.
the time to stops on the lines should be to DTX, state, Park, and government center
YES. God, yes. If not for that, at the very least please improve the contrast. The Green Line's displays are horrendous from a distance.
As far as I know the upcoming 3600's rebuild doesn't include swapping out the signs. But we might get surprised...so wait and see what prototype rehab car 3614 looks like when it comes back from the factory shiny and new in about a year.
It's not hard to swap out the displays, though. The crusty old 1994-95 era RTS buses all got their awful old LCD's done up with the same LED's (internal and external) as all the new bus purchases. They could very easily rotate the GL fleet through sign replacements at Riverside with each car being out of service no more than a few days. It just takes an onboard firmware upgrade for the ASA to do all the different tricks with the signs.
I went looking for ways to straighten out the NEC between New Haven and Rhode Island.
http://goo.gl/maps/xixdE
Won't work:
-- I-84 looks cool on a map, but it would require a tunnel boring machine through some of the hills in Tolland County and lots of superelevation in others. Especially that huge hill between Exit 68 and the Willington rest area...that's going to have to be a 1.5 mile tunnel because there's no way around it that doesn't hit equally steep rise. RR's can't exceed 1% recommended grade, 2% max. Price becomes a killer with I-84 well exceeding the maximum. And you would have trouble keeping equal bi-directional schedules because EB has to so constantly climb hills it would run slower than WB which is almost constantly downhill. I think this one has a lot of unsolvable engineering problems because 2D straight line ≠ 3D straight line.
Will work:
-- Definitely the NYNE out of Hartford is very fast and straight. All grade crossings except for the 3 tough ones on Tolland Turnpike can be eliminated easily. You just probably have to do some relocation around Tolland Tpke. to get rid of those. Not hard, though, because that vast wasteland of 84/291/384 interchanges leaves a large canvas for reworking. I bet you could come up with 10 viable ways to do that one...it's almost a non-issue.
-- I assume your Bolton-Willimantic routing is a variation of the rail-on-384-median two-fer. Note that the highway proposal with 1000 ft. greenway median that nearly got approved in 2004 before the Army Corps spiked it was the north-of-Hop River routing. The south-of-6 routing you're following here was the one that required too many property takings for the locals to support. So you'd need to flip-flop that line on the map to about the same spot on the north side of 6 and the river, then meet up with the old ROW at Pucker St. and follow it downtown to the pair of NECR junctions. Otherwise you've got exactly the right idea here.
-- Your northerly route Willimantic-Plainfield follows the would-be 384 ROW to 395 almost exactly. That'll definitely allow HSR speeds...no question.
Won't work:
-- The NYNE/Hop River routing does require you to use the old ROW between I-84 Exit 65 and the 384/44/6 interchange, so you can't straight-line it between Manchester Ctr. and Bolton. You'd slam headfirst into a rapid 600 ft. rise on the straightaway drawn on that map, which is no-go. The old hairpin through Bolton Notch State Park is necessary to thread between those grades, so there would always have to be a speed kink there if you're going to Providence via Willimantic. I don't think that's a problem, though, given how straight the NYNE is out of Hartford and how straight it could be made from Bolton to Willimantic if it followed 384. Figure you've got continuous 125 MPH on the west side of the hairpin, and continuous 125 with bona fide long stretches of 150 along the 384 median to the east of the hairpin...so one single 60 MPH restriction is a drop in the bucket. It's only when the ROW never stops twisting, like the Shoreline, where the speed penalties add up.
-- Very difficult and likely impossible to do the southerly route to 395 paralleling the active Willimantic Secondary. You slam into several 400 ft. rises, which won't work with RR grades and would force a curvier route than you've got on the map. The Willimantic Sec. hugs the river and twists like it does because that's the way to avoids the hills. So you'll never get something straight enough through that terrain to be speed-competitive with the 384 median. Axe this one and go with the very feasible northerly route.
-- No way to continue the 384-running past Plainfield to Providence. The hills in Foster and Scituate, RI are extremely steep...a series of 500 ft. and 600 ft. rises not unlike 84 in Tolland County. And there's no way to fit highway + rail along Scituate Reservoir. The Reservoir is what killed the highway alone in the 35 years they were trying and failing to build it.
Will work:
-- The NYNE routing east of Moosup to West Warwick is very straight. I'd absolutely stick to the old routing here. Have to deal with the S-curve along the river in Warwick and do a lot of grade crossing eliminations on the last 10 miles, but it junctions very cleanly with the NEC and you'd be able to speed into Providence station faster here than the NEC itself because the Shoreline's S-curve in Cranston is worse and a bigger traffic clog with slow speeds into the junction. To jump from 384 to Moosup you would have to install a wye onto the P&W main right where 384 would cross Route 32, head straight down about a mile, and either wye again at the old one-way P&W/NYNE junction or straight-cut around Moosup Pond (and the houses there) to meet up with the NYNE where it straightens out north of Route 14. I think straight-cutting works here if the NIMBY's don't kill it because downtown Moosup is a curve-a-thon and the old P&W/NYNE junction is on a very sharp angle. I don't think the speed restrictions of a P&W jog would be bad if you made the two wye curves wide enough to hit at 40-60 MPH. For Regionals you'd probably want to have a station around here anyway to serve transfer traffic on P&W and park-and-rides from the 395/384 interchange.
Whither Worcester?:
-- If you want a Worcester leg you've got two dilemmas: run all traffic through that Plainfield-via-384/P&W junction and do an L-shaped routing north, or reactivate the Air Line between Willimantic and Putnam and get a straighter shot and a shorter Putnam-Worcester P&W jog. P&W would absolutely support 125 MPH speeds most of the way because it's so very straight north of Plainfield, and avoids the hills that would tax the speeds on EB trains running on your I-84 routing.
-- The Air Line gets the straighter-line path out of Hartford/Willimantic, but would need a lot of curve straightening because it threads the needle around some mid-sized hills. Same 2D straight line ≠ 3D straight line problem, to lesser degree, as the 84 routing. The old Air Line wasn't exactly all it was cracked up to be as an old-timey higher speed bypass because of those Eastern CT hills. I think you could finesse it a bit, but it's never going to be so straight through Windham County that it can more than 90-100 MPH at most (with some 60 MPH restrictions).
-- So I think, even though the L-shape out of Plainfield looks much more indirect a map, it does take the crown as fastest Hartford-Worcester shot (by a hair) over any other route if P&W gets the right north-south upgrades. You can definitely do 125+ and 150 in good stretches the whole length from Hartford to Plainfield, and P&W is straight enough for 125 in most places. And would allow for maxing out the infrastructure here where a split in Willimantic would make the traffic a little too diffuse and too far below track capacity through Eastern CT.
So, to recap...most viable:
1) NYNE/Manchester Secondary Hartford-Bolton Notch on existing ROW, except for rework around 84/291/384 interchange to zap grade crossings. 125 MPH (ROW geometry would support 165 MPH segments, but figure dense commuter rail traffic/station spacing out to Vernon); 60-80 MPH through Bolton Notch (1 mi.).
2) 384 greenway median, Bolton-Willimantic. 125-165 MPH range.
3) Short stretch of NYNE + NECR ROW, downtown Willimantic (< 1 mi.). 40-60 MPH, within Willimantic station approach limits.
4) 384 greenway median, Willimantic-Plainfield. 125-165 MPH range.
5a) SB wye from 384 onto P&W in Plainfield. 40-60 MPH, within Plainfield station approach limits.
6a) P&W for approx. 1 mi. 80 MPH.
7a) EB wye in Plainfield onto NYNE. 40-60 MPH.
8a) New alignment for 3/4 mile in Moosup to avoid curves (if it passes NIMBY + environmental muster). 90 MPH.
9a) NYNE/Washington Secondary existing ROW to NEC, with grade crossing eliminations. 125-150 MPH Eastern CT/Western RI, 80 MPH Warwick-Cranston around curves and dense commuter rail traffic.
10a) Existing NEC to Boston. 125-165 MPH.
5b) NB wye from 384 onto P&W in Plainfield. 40-60 MPH, within Plainfield station approach limits.
6b) P&W active ROW to Worcester (maybe a couple short/< 1 mi. bypasses in downtown Webster and Auburn adjacent to 395 to zap some grade crossings). Some--but probably not 100%--other grade crossing eliminations. 110-125 MPH.
7b) Existing Worcester Line to Boston. 125 MPH, tri-tracked Worcester-128 and in Allston, grade separated Ashland/Framingham.
You can blast straight through the hills. A certain degree of topographical reconfiguration is to be expected here - especially if you're median-running 384/swinging on a completed Hartford-Providence-New Bedford-Cape Cod Interstate 82. This holds true for every other hill that may or may not be in the way of a Hartford-Providence connection.
I've got nothing for what you do about the Reservoir, though, but you have to do something because...
Will work:
The Washington Secondary is dead and gone, the earth's been salted with a bike path (and is under the "protection" of the Greenway Alliance of Rhode Island) and you are never, ever, ever reactivating it again. Sorry.
We're not getting Hartford - Providence done without some expensive landscaping, no matter if it's a highway link, a rail link, or road + rail.
Wait, wait...are you actually suggesting that blasting through hill after hill after bloody hill is easier to swing than de-landbanking an existing ROW that supports comparably high operating speeds??? I don't think you're going to find much company in the dystopian universe that idea inhabits. Sorry, CBS...you're playing Robert Moses scorched-earth mapmaking again with that one. Set some personal Crazy Transit Pitches limit on these schemes that if the build is >10x harder, more disruptive, or more expensive than the functionally minimum-build alternative. If there's that stark a difference between two routes of similar operational characteristics that go the same place, you will never ever--in any funding environment--get political consensus to go the path of MOST resistance. 1960's urban renewal taught people to very viscerally hate being dictated from on-high that their homes, communities, and the landscape around them are unilaterally expendable in the name of "progress". They learned to instinctively rebel against that when planners blow off any pretense of consensus-building ("consensus-building" ≠ "see it my way"). Even when the build is in their best interests, they'll rebuff it on that attitude alone. This notion of yours that raw firepower can build anything if we only threw enough overpowering firepower at it is poisonous overreach to the real world.
Find another way to solve a real-world problem. Brute force doesn't work like that in this country.
NIMBY's run roughshod over the landbanking provision because politicians are so compromised by their own special interests that they fold like a chair and actively encourage those games. At the end of day, however, the landbanked ROW is a legally protected transportation corridor with an active operating charter to run a railroad over it. It only has to be re-permitted up to modern regs, unlike an all-new ROW where the cost of mitigation is totally uncapped and no-go environmental rulings are a very real risk. If someone cares enough to enforce the landbanking statute, reactivation can be legally enforced. This is all about political will. The ones that get blocked never had unified enough support to happen to begin with. And, yes, the depressingly low number of successful de-landbankings accurately reflect how soft the support is for actionable rail builds in this country. But if it's a "must-have" that draws robust support at a statewide level...no, it is not possible for a small number of NIMBY's to block it. They're outnumbered on raw votes, and the landbanking statute doesn't afford them the loopholes for a unilateral block.
NIMBY's, however, are not a single political constituency unto themselves. If it comes down to abutters on a landbanked ROW vs. foisting a more disruptive build on residents elsewhere...the NIMBY's are going to lose in a rout. Local example: Raynham's vs. Norton's & Attleboro's internecine warfare over South Coast FAIL routings. Raynham threw every barb it could to get the project off the landbanked ROW onto their neighbors' active grade crossing gauntlet, knowing full well what a clusterfuck that routing would be and arguing that their minor inconvenience trumped Norton and Attleboro's known-known surefire clusterfuck. The return-fire was so withering they got dealt a fatal defeat with the Stoughton Route being the *only* recommended routing eligible for a build. Other local example: Grafton & Upton RR restoring out-of-service (not even abandoned) track in West Upton. Board of Selectmen made a suicide pact to do everything it could to stop a project it couldn't legally stop. And it ended up getting them slapped with a defamation suit by the RR owners and two-thirds of the town voting against the other third to stop the embarrassing fishing expedition with taxpayer dollars.
You can't win making that many more enemies than friends. Even grading on a curve, friends in high places don't do enough to drown out raw math after awhile. The numbers game doesn't work in their favor when the build has to go somewhere. West Warwick isn't going to prevail in a 5-on-1 fight against every other affected legislative seat and two states' worth of Congressional reps if the states are dead set on there being a Hartford-Providence connection somewhere. If NIMBY appeasement means spending 10x the money at 10x the permitting peril and 10x the engineering difficulty for the same damn infrastructure in somebody else's back yard who didn't choose to buy property abutting a chartered ROW...the NIMBY's go down to defeat at 10x the margin. War of attrition of that sort only works when support can be divided and softened enough that "nowhere" wins over "somewhere". When it's gotta go "somewhere", and there is no other "somewhere" that makes ⅛ sense, NIMBY games don't even work for the likes of the old money that threw the kitchen sink at stopping Cape Wind.
I think the engineering challenges of all these proposed inland paths are going to whittle it down to the NYNE through Rhode Island as the only feasible "somewhere". If the support for "somewhere" ends up far stronger than "nowhere"...suck it up, Washington Secondary abutters, you're not going to prevent it.
Yes, because if you're really going to be running it inside the median of an interstate highway, hills are getting blasted through anyway. Taking the future NEC out of the median does not change that, and since this is the only place where we might conceivably ever make the highways work for us instead of against us, it's objectively foolish NOT to take advantage of the swath of hill-related destruction that's coming down the pike either way.
If, on the other hand, the highways exit the picture entirely, then it's a different story. In that case, the Washington Secondary is still an objectively bad ROW because there's already an existing 150 mph stretch south of Cranston, through the Airport, and on down to Kingston. Maybe/maybe not that's eventually 165+ territory, certainly it can be four-tracked, and it's a stone's throw away from the Washington Secondary anyway. Do you really, honestly believe that there's going to be enough critical mass backing the Washington Secondary routing to overcome the opposition it would face, especially when it's so close to active 150+ MPH track? That's just as much a scorched earth decision as blowing up a bunch of hills in the countryside. Only difference is, hills can't grab the ear of polticians. People can.
The Washington Secondary is not coming back. Sorry, pick another route. My two suggestions would be trying to swing around the north end of the Reservoir, or take advantage of that unpleasant looking right turn past the south end of the existing 150 mph stretch to try and reach Plainfield or Norwich from there, both of which look to be relatively clean shots through totally undeveloped countryside.
No Blasting is needed , you build tunnels like Europe....they tunnel under small towns , farms and of course mountains for highways and railways...
