1. I agree a the Busway is a Boondoggle it has stalled the Streetcar plans for New Haven , Bridgeport and Stamford. The Ridership is only 14,000 a regular bus can handle that amount. You start talking about busways when Ridership hits 50,000. Hopefully it gets killed , once the project went above 50 million it should have been killed... I don't think the South Coast Rail is a bad idea , as long as the Cape Cod and Newport lines are added right after its built. That part of New England has a growing elderly population and you don't want them to drive , most will not use buses. The Economies of New Bedford , Fall River and Newport could use an inject , down the road anything feeding into a NEC City will have a strong economy. You have to look at projects like that will a long term prospective.
2. I think the Danbury Branch is higher then the Shoreline East Extension to Westerly. Between the Sidings , and Infill stations Ridership is expected to grow to 15,000 or higher depending what goes up in Danbury and Norwalk. The Downtown Master Plans for both cities although super dense housing near the stations.
3. I took the Airport Branch off I don't see a reason for it nor do I ever see becoming reality...a shuttle bus is better...
4. That seems to be a New England problem , Busways are overtaking Rail but instead of being cheaper they end up double of the cost and don't attract much ridership. But i'm sure they find a way to thread the commuter rail through New Britain and too Hartford.
5. I think it should be Electric , infact the entire Eastern System should be Electric based off current and future growth projects. I think the system for Hartford should be a mini RER system , Manchester - Bristol line....and the Knowledge Corridor Commuter rail.
I'll add my opinion later...
SLE to Westerly is #2 only because it's low-hanging fruit. Not a single upgrade required by CDOT assuming Amtrak is the party raising the platforms at Mystic to high-level, and Westerly layover can be shared by both SLE and RIDOT. It's essentially a 0% capital investment, 100% operating investment for the state. No-brainer to let-er-rip the second RIDOT touches down at Westerly.
As for electrification, it doesn't make sense for the Springfield Line until they zap all the grade crossings south of Hartford. Almost all of them are problematic, whereas north of Hartford it ain't bad. The speed restrictions in Wallingford and Meriden around those crossing clusters are absolutely punitive. I think it's a far better initial investment to pour the money into eliminating the crossings and pushing the line to a uniform 90-110 MPH...THEN string up the wires a decade later. As long as the speed restrictions are there it's going to significantly blunt the electrics advantage. The state talks fancifully about wanting the wires because it's a Big Thing™, which is worrisome because they don't talk about the grade separation. Cart before the horse. It's very much a sequence they have to go through...get uniformly fast diesel first, then fast electrification.
Until Inland HSR comes to town, I don't see frequencies here that merit electrification on any other lines save for Danbury. And even with Danbury I'd hedge on a New Milford diesel extension as first priority since the funding pie is simply not large enough for both in one decade. Off-peak service is going to be light, and outside of maybe a DMU shuttle to Vernon or Bloomfield/Bradley the stop spacing everywhere (including the Springfield Line) is pretty mundane push-pull distance. Do Springfield for sure after they've done their homework with the grade crossings, but otherwise I think diesel is perfectly right-sized here until Amtrak gets ready to build that east-leg HSR segment. Maybe punt the Waterbury Branch out of the Metro North district into the Central CT district if/when Danbury goes electric so the modes are somewhat centralized (Waterbury's the biggest MNRR outlier to begin with, being the only branch shuttle that doesn't have at least a couple thru trains to Grand Central).
