You don't even have to get crazy to deal with the single-track bottleneck nightmare.
Two new switches at Savin Hill. That's it. You get two new track switches to move Braintree Trains into Savin Hill station, and bam - you didn't just solve your bottleneck, you went from one track to three and you didn't even need to do anything crazy to make that happen.
(Also, you got rid of the weird double-platform JFK/UMass setup, and that's priceless.)
Damn, I had been sure the OCRR now ran single-tracked all the way down to Braintree...
Okay, actually, looking at my charts again, I was sorta right. Between Park Street in Dorchester (just after the Ashmont Branch heads west) and Squantum Street in Quincy, it is double-tracked. But according to my information, south of Squantum, it's single-tracked again.
That was what I had meant to improve with my crazy Red-to-Indigo idea.
Obviously, though, the Savin Hill bottleneck is more of a problem, and I'm not sure the payoff of increased CR capacity is worth losing 5-stop rapid transit service in Quincy.
I corrected that....i forgot about the Tremont Tunnel , is it still intact?
Yes... though not quite on the alignment on your map. The Tremont Street Subway extends south from Boylston Street Station to a sealed/covered portal at what is now Eliot Norton Park, just north of Oak Street West. (But only that far.)
Most proposals that use the Tremont Street Subway have the Green Line surface at Oak Street and find their way over to Washington Street via Marginal Road or Herald Street. Trolleys then head down Washington Street to Dudley.
To my knowledge, there has never been any subway tunneling of any kind inside the South End, east of the Southwest Corridor, in any case.
Don't forget to rebuild the flying junction south of Savin Hill...
Okay, fine. Two new track switches and a new junction - still totally reasonable, if you ask me.
It's not - but the single-track south of West Squantum Street (right around North Quincy, actually) only lasts until Quincy Center and there's plenty of room to add a second track there if need be. I'd be willing to go as far as to declare it a complete non-issue if we fixed the mess at Savin Hill.
There are things I like and don't like about your map, Nexis. While I am all for expansion of the Green Line (see my earlier map), when you reach this level of complexity, I think it might be good to begin differentiating services based on color, not just letter. (ie. split the Green Line up into a Green Line, Gold Line and Teal Line [or whatever]).
Some specifics:
-While I admire the creativity of extending the B out to Auburndale, I don't really find it plausible at all, especially given how close it gets to the D at Newton Center. Maybe the demand exists; I don't know. But I have yet to see the ridership stats to suggest that it does.
-B to Auburndale but no E to Forest Hills?
-I'm not loving the Mattapan via Seaver alignment of the Green Line. If you must route it through Huntington (and I can see how you would feel that you did), I would route it over to Ruggles station, down Ruggles Street (yes, it's oneway, but that can be solved easily enough) to Washington Street, through Dudley Square and down Warren Street. As it is now, the trolley duplicates the Orange Line almost precisely for a mile and a half.
-All those GL branches and still no cross-Cambridge service? You could run it down the Grand Junction, down Prospect to Central, down Kirkland to Harvard even.
-Actually, looking at it again, I've realized that there is no circumferential rapid transit service to speak of. This is essentially an expanded hub-and-spoke system. Not feeling that so much...
-Not sure I'm crazy about sending the Mattapan Line down to Readville. Looks like you duplicate service a lot down there, between the Mattapan Line and the two Indigo Lines.
-You argue that HR expansion is expensive, but you've extended the Orange Line out to meet a branch of the GL in Needham. I used to do this myself, but it seems pretty clearly overkill now. Needham is not a HRT-friendly environment, so I don't see why the OL should go that far.
-No Indigo Line to 128/University Park?
-While I like the idea of a South Shore Indigo Line, I'm not sure what you get by only running it down to Braintree. I mean, yeah, express service from Braintree, Quincy Center and JFK/UMass, but that already exists as CR and isn't wildly popular.
Honestly, if we're getting really crazy here, I would convert the entire Braintree branch of the RL to DMU/EMU, to allow CR service to utilize those tracks as well, removing that single-track bottleneck nightmare. Maybe cut away a few stations, and replace the Red Line with a streetcar network. Quincy is certainly dense enough to support one.
Things I like:
-Indigo Line to Wellesley.
-Blue Line to MGH *via the West End*.
-Red Line to Southie
-Blue Line to Lynn, with agressive Indigo Line expansion along the rest of the North Shore
-Green Line to Arlington
-Green Line to Revere
-Green Line to Waltham, from north and south
1. I broke it up into the Gold & Green lines , Lines going Northwest and East will be Gold....lines the rest will be Green line.
2. I believe the more connections to Regional Rail , the higher ridership will be on that line. Theres enough space on MA 30 in the Median for the line...so why not extend it?
3. I forgot to put in the E to Forest Hills...
4. I moved around the Mattapan Green line , it now uses the Tremont Subway and is straight through Roxbury.
5. I don't think theres a need for cross Cambridge service....maybe thats just me...
6. Really it seems that an Orange line to Needham would be easy and would double line ridership..
7. I don't know where University Park , i'm assuming its on the Franklin line. I hate office parks like 128 so I wouldn't want to encourage investments their...I would like to see it die off...
8. I extended the Old Colony Indigo line to Brockton...
I really, really don't like the sound of that. Sounds like a pretty severe S-curving pattern to me.
Herald Street and East Berkeley Street don't really rate as tremendously important stops for me - why not axe them, keep the Green Line submerged and punch out a new tunnel like this?
University Park is, in fact, Route 128 Station. (Amtrak Conductors will occasionally go ahead and announce it as Route 128 - University Park - Westwood/Dedham, MA.)
Cool cool.
Fair enough. I'm still not sure the cost-benefit ratio pans out, but that's the only real argument I can come up with. God only knows, I'd love to see a suburb like Newton let go of their cars.
Thank you. :) Looks much better now.
Are you proposing a subway or street-running service down Tremont? I'm curious why you're having it go down Tremont as opposed to Washington.
I see what you mean, it's just that your system now still requires folks to go downtown to transfer to another line. The crosstown service wouldn't so much be for going, say, Union Square to Central Square, as it would be for going Union Square to Allston or Newton. Do you see what I'm getting at?
I mean, honestly, I'm not always sold on the Urban Ring, etc., so I can understand your reluctance.
I believe you would have to rebuild a bridge over Route 128, so that might be an impediment right there.
And two services might actually "divide and conquer" the target ridership. Let's say that there are 4000 commuters in Needham who want to go into Boston each day. (FWIW, that's the current CR boardings times two [multiplied because of higher frequency service. Totally arbitrary, just bear with me].) 4000 period. One of three things will happen with those 4000 riders:
A) They will all take the Green Line. Result: very popular Green Line, wasted Orange Line.
B) They will all take the Orange Line. Result: very popular Orange Line, wasted Green Line.
C) Some will take the Orange and others the Green. Result: neither line is operating at peak capacity.
(For comparison, 4000 is approximately equal to the sum of the current boardings from Riverside, Newton Highlands and Newton Center.)
On the other hand, if we can reasonably expect that two RT lines will promote growth in Needham, then great. But I don't think we can expect that.
"University Park" is the bizarre "official" name for the current Route 128 station currently serviced by Amtrak and MBCR. It is a very successful park-and-ride and is certainly successful at taking cars off of I-93.
Very cool, I like.
I don't like the idea either, I was just framing it that way because Nexis (I believe) wants to avoid tunneling as much as possible. As annoying as the S-curves are, we're talking about streetcars here that would have to stop at the stop lights anyway. So I'm not sure how bad the S-curves really would be, functionally.
For what it's worth, I would resurrect the portal in the park, run down a block on Shawmut, construct a new diagonal crossover from Shawmut/Marginal to Washington/Herald and continue down Washington from there. From the little I know of structural engineering, that strikes me as the least difficult alignment.
Washington and Shawmut could also work as one way pairs all the way down to Dudley.
Gotta figure out what to do about the narrow stretch of Warren Street coming into Blue Hill Ave - probably the one section of the route that doesn't allow for a median.
They would be BAD.
The nature of an S-curve is that half of it has to be a left turn. Left turns are bad news, which is why UPS goes out of its way to dispatch its drivers on routes that avoid as many of them as possible. Even if we had signaling priority, turning left would still be worse than just tunneling or building a flyover.
^^Aha, okay, yeah, that makes sense. Don't do much driving these days, so I sometimes forget that not all turns are made equally.
But that aside, I still don't see why building a transitway diagonal overpass over the Pike isn't a better idea than tunneling under the Pike.
Palatability concerns, mostly. People will find a tunnel much easier to swallow than an overpass (think NIMBYs clutching pearls over shadows.)
Although, since this would only be over the Pike, I'm not sure that would really apply.
Yeah, what I'm thinking of is basically another bridge over the Pike on the same level as the street overpasses. It could be a street overpass, except that only trolleys (and maybe busses) would be allowed on it.
No shadows. Residents probably wouldn't even notice it.
Connecticut Rail & Transit - 2050 Plan
By 2025...
Knowledge Corridor Upgrade - New Haven - Brattleboro - 110/125mph
Danbury Branch Infill Stations , Sidings , and Electrification
Waterbury Branch , Sidings , and upgrade
Shore Line East 3rd Tracking , High Level Platforms
Central Corridor - New London - Brattleboro
New Britian - Hartford Busway
Stamford Streetcar ?
New Haven Streetcar ?
Beacon - Maybrook line
Pittsfield line
https://maps.google.com/maps/ms?msid=215312482559953359515.000491cc098e4e5fc7e31&msa=0&ll=41.656497,-72.246094&spn=5.539837,13.392334
http://blog.visual.ly/how-to-design-transit-map-style-graphics/
I figured this was relevant to the interests of this thread. I just stumbled across it, actually.
I was going to go ahead and take a crack at designing and pitching my own map with this - but I need some help.
So, at the risk of turning this into the 'Transit Pitches by Committee' thread...
Do you guys think that it's better to have route lines touching, or slightly spaced apart - ad should all the lines be given the same line thickness, or should HSR / high frequency services be emphasized?
Basically his advice is "use a vector graphics editor" to which I say "no duh."
A lot of it is aesthetics so those choices you are asking us is something you'd have to decide really.
Though I will put in a good word for showing frequency through line width.
Yeah, that's a tough spot. I think a few blocks of street running shouldn't be seen as a reason not to do it. Almost the entire line could be done really well given the space on Blue Hill Ave. and Washington St. (and indeed most of Warren). A few blocks of traffic induced slow down won't make the corridor ineffective for rail.
I'd propose that the trolley maintain dedicated space even on that stretch of Warren, which would leave room for only one auto traffic lane. I'd designate that for northbound only car traffic, one-way. Southbound traffic currently using Warren can be diverted to Walnut Ave/Humboldt/Seaver to connect back into Blue Hill Ave, and that still allows for access along both directions to Boston Latin.
By 2025...
Pittsfield line
If there is justice in this world, that lifeforce-sucking busway will get killed off by a lawsuit from Newington and West Hartford over the destruction to be wrought by the ramps scheduled to be built on the Amtrak ROW. It's the worst-kept secret in the world that West Hartford is trying to find every legal loophole it can look for to launch the killshot. Perhaps the only transit project in the country a more senseless waste than South Coast Rail.
-- New Milford extension of the MNRR Danbury Line is an actual proposal with solid, solid fundamentals: http://www.danburybranchstudy.com/. Separate that one out from the Caanan/Pittsfield proposal, which is by the private Housatonic RR. Brookfield and New Milford have been suffering for decades from the cancellation of the US 7 expressway. This is easily the #3 passenger rail extension priority in-state behind New Haven-Hartford-Springfield and Shore Line East to Westerly, RI.
-- Forgot the Bradley Airport spur on your map. That's an official appendage to the NHHS proposal. Although, really, until there's some multiple service configurations out there I'm not sure a "dinky" on that line is going to offer any advantage over a shuttle bus from the mainline stop.
-- If the @#$% busway would just die-die-die, "New Britain loop" service on NHHS would be good and cheap. Divert up from Berlin, return to the main on the NB Secondary. Route every third NHHS train that way.
-- Speaking as a Bristol native, Hartford-Waterbury commuter rail would be quite very well patronized. That one needs to happen. Although it's going to be hobbled if it has to use the Berlin Branch because the godawful busway is hogging the New Britain Secondary. Has had consensus political support for years...the DOT is just drinking the BRT kool-aid by the metric ton.
-- Hartford-Manchester/Vernon is a quickie on active track that would be very beneficial to do. Hartford, East Hartford Ctr., Buckland Hills, Manchester Ctr., Vernon/Exit 65 would be well-patronized. Only about a mile of abandoned track between end of the freight line and Exit 65 to put back. I'd rank that behind NHHS, New Milford, and Hartford-Waterbury. Could work as an east terminus for Waterbury-Hartford so there's an "I-84 line", or DMU's would work well on a short shuttle.
-- Obviously the Willimantic gap needs to be filled. State's flagged that a high-priority future consideration in the official State Rail Plan. "Suicide 6" is not going away as one of the most acute road problems in the state, it's a bona fide commuter rail market with the easy continuing connection to New London, and it's the only way to link UConn to the rest of the state on public transit. Only question is where. I think passing on the landbanked ROW in favor of rail on the I-384 extension "greenway" median is the way to go. Dust off the proposal that was fed fast-tracked from 2001-04 before the Army Corps played politics and spiked it, and put rail on the 1000 ft. median. Grade the curves to support future Inland NEC speeds, and open it as a regular 80 MPH diesel line with double-stack freight clearances (opening up a crucial Hartford gateway for the oversize freight NECR and P&W already move to Willimantic). That gives the whole deal enough environmental mitigation juice to placate the Army Corps., and achieves cost efficiency by doubling-up the rail and highway in one EIS.
-- The Eastern CT proposal for service on the NECR main from New London to Willimantic is a real one. And running hot at the moment. NECR is privately dangling that one right now in conjunction with the local Chambers of Commerce and MPO's. They want it because of the freight track improvements it'll buy them, but they're offering to buy some passenger cars and run it themselves because they think there's a little bit of revenue to pinch from the giant casino bus business. NECR runs directly alongside Mohegan Sun and has 60 MPH track: http://goo.gl/maps/lZnZo. Limited service here with the public-private partnership would get it entrenched enough to up the demand for the Manchester-Willimantic connection to be restored and bona fide Hartford-New London commuter rail (Route 2 commuters just got a faint twinkle in the eye at that thought).
-- P&W is making goo-goo eyes at the state for getting passenger service on its east-of-river New London mainline, so that's a real proposal too. There used to be a Worcester-bound intercity train that used this line through Day 1 of Amtrak before it got cut. Like NECR, this is good 60 MPH track. Unfortunately 395 is well below capacity, Norwich is also hit by NECR, and there isn't potential for a direct casino stop here. But New London-Worcester is pretty intriguing--and inexpensive--as a future consideration.
-- Not on your map, but possibly worth considering as a DMU line: the Griffin Secondary, Hartford-Bloomfield. This was a light rail proposal for almost 20 years until killed in the 90's. Splits the difference between 2 of your streetcar lines and could have a direct U Hartford campus stop. The state has earmarked ROW from back in the light rail proposal days from the end of the line in Bloomfield, across the Farmington River, and on power line land which it could purchase to bring the line to Bradley Airport and connect to the stub end of the Bradley Branch. It's still an active freight proposal, albeit low-priority. If the Bradley connection were made contiguous then that becomes a pretty nice-looking Hartford-Windsor Locks shuttle serving the canceled I-291 corridor and some dense residential in Hartford and Bloomfield. Low-low priority but I think a better future consideration than the streetcars or those redundant CT River-hugging commuter lines.
Those are the ones that are grounded in some decent 20-year reality. I don't think these are going to have much juice:
-- Torrington extension of Waterbury Branch. Route 8 is free-and-clear north of the I-84 interchange. It's an easy drive to Waterbury station from Torrington. There'd be slightly more of a market for Torrington-Hartford because 84 is such a nightmare, but the only way to swing that one is a reverse move at Waterbury. Naugatuck RR runs some very nice excursion service on this line through pretty country, so the line is a going passenger concern. But the potential CR market here is very minimal. Nothing at all like Waterbury-Hartford.
-- Beacon Line, west-of-Brewster. Take one look at how twisty this line is and some of the godawful grade crossings on it. There is no way possible that Metro North could ever run branchline service on this thing and keep any semblance of schedule order on the Hudson or Harlem lines. It's been studied. The ridership is dubious for how constrained the infrastructure is. Also keep in mind that the "advocacy" for Beacon Line commuter rail pretty much boils down to ONE guy who runs a half-dozen websites pushing the idea and spams RR.net and every media outlet comments section to oblivion about how this thing's got real momentum. He's a little...off in the head. But is damn prolific.
-- Middletown Secondary commuter rail. Too close to the Springfield Line, and other than the traffic light clusterfuck in downtown Middletown (which could be fixed ASAP if businesses in downtown didn't keep blocking the grade separation) Route 9 operates slightly below capacity from Berlin to Old Saybrook. Will see much heavier freight traffic in the future as a diversion to Springfield Line traffic.
-- Valley Line/Old Saybrook commuter rail. Same deal...CT 9 just isn't that bad a highway. And a thru-routed NHHS/Shore Line East train that covers Hartford-New Haven-Old Saybrook will get there faster on straight fast track than the twisty Valley Line. No need whatsoever for this. However, if the out-of-service segment of the Valley in Higganum gets reactivated (planned, but state has no money) the Essex Steam Train wants to extend its service to Middletown and run excursions straight to Hartford. Which'll be really nice. That's a very popular tourist line as-is.
-- Air Line/Middletown-Willimantic. Total nonstarter. This route failed the first time around for good reason...totally skips all the population density. "Right-angle" trips off the Springfield Line NH-HFD-WIL are probably gonna be faster anyway when Springfield gets speed-boosted >90 MPH.
-- Maybrook Line, Danbury-Derby. Twisty line, inadequate pop density because it hugs the river inside a linear state park for too much of the distance. The old segment from Derby-New Haven is long-abandoned, so it's also a lot more indirect a route out of NH than it used to be. Good freight bypass for the New Haven Line...P&W was fighting Housatonic RR in court for them to fix up their damn track so it's a sought-after chess piece amongst freight competitors. But that's all it's good for. Nonstarter for passenger.
-- Danbury-Caanan/Pittsfield is an actual proposal from Housatonic RR. But it's a laugher. The Berkshire Line needs >$100M in repairs for subsistence-level freight service, and nobody wants to touch Housatonic because they're a largely discredited outfit. CT and MA both canceled all TIGER grant apps in the queue for Housatonic out of concerns they'd just pocket the money and fuck off. This line is so far in the hole on state of good repair it's going to take a generation before passenger upgrade costs look remotely palatable (beyond the MNRR New Milford extension). MNRR would almost be better off rebuilding the totally abandoned Harlem Line back to Chatham than touching this mess. Really don't think this is a good one at all.
-- Beacon Line, Brewster-Danbury. Housatonic RR has been pitching a plan for service here. Also a laugher, because Housatonic has napalmed so much goodwill launching petty spats with MNRR that the chances of them EVER being allowed on the platforms at Danbury and Southeast are nil. So much ill will seeded by their Internet Tough Guy V.P. of Business. If there's any justice that carrier will be out of business in a year and somebody competent like P&W will scoop up their territory for a song. Brewster-Danbury would be very convenient for alt Danbury service patterns from the MNRR Harlem Line if the wye at Southeast station were restored, but Metro North has studied it and the interest level from Harlem Line commuters is minimal. Money much better spent on spiffing up the Danbury Line. However, this is a much more viable future consideration than the west half of the Beacon Line because it's at least grade-separated, mostly straight, and offers pretty straightforward connectivity.
-- I do not see streetcars returning to Greater Hartford at all, or the need for it. Most of their transit needs can be better served by making CT Transit a less-shitty bus system and providing good commuter rail connections. The route coverage is pathetic. It's got at least 2-3 more gears it can reach for.
-- New Haven and Bridgeport are mulling their streetcar plans, but in NH's case it's a beltline type thing. Too much wishful thinking that either are going to have anything resembling a real network in place. Like Hartford both cities would benefit from less-shitty bus coverage. And they're still too car- and parking lot-centric to realize the upside of a halfway-extensive build like Providence would. Too much wishful thinking here.
-- Not on your map, but I'd also avoid the Armory Line East Hartford-Suffield. That was a slightly laughable BRT proposal in the 90's back when the line was mothballed for freight. Even closer to the Springfield Line than the Middletown Secondary, and if MA reconnects the abandoned portion from the state line to Springfield (which CT and Amtrak badly want) it'll become the primary freight bypass to Hartford and a double-stack route.
Note also: the Inland HSR proposal does use the existing Manchester Secondary at least to Vernon because that's the old intercity route and was built straight, mostly grade-separated, and high speed. Also is slated to use the New Britain Secondary and existing ROW to Waterbury because that was the former high-speed route. The only nightmare there is the downtown Bristol hairpin, which would have to be tunneled-under with a bypass (good luck with that). I still think the feds are smoking crack if they think they're going to be able to plow through from Waterbury to Sandy Hook to reconnect it all. The community opposition is going to be severe out there, and more severe still in Westchester County. East-of-Hartford...yeah, they're in solid shape esp. if it can get bootstrapped on the 384 extension. But this whole vision is going to have to be Springfield Line or bust. The hurdles are just too great out west.
1. I agree a the Busway is a Boondoggle it has stalled the Streetcar plans for New Haven , Bridgeport and Stamford. The Ridership is only 14,000 a regular bus can handle that amount. You start talking about busways when Ridership hits 50,000. Hopefully it gets killed , once the project went above 50 million it should have been killed... I don't think the South Coast Rail is a bad idea , as long as the Cape Cod and Newport lines are added right after its built. That part of New England has a growing elderly population and you don't want them to drive , most will not use buses. The Economies of New Bedford , Fall River and Newport could use an inject , down the road anything feeding into a NEC City will have a strong economy. You have to look at projects like that will a long term prospective.
2. I think the Danbury Branch is higher then the Shoreline East Extension to Westerly. Between the Sidings , and Infill stations Ridership is expected to grow to 15,000 or higher depending what goes up in Danbury and Norwalk. The Downtown Master Plans for both cities although super dense housing near the stations.
3. I took the Airport Branch off I don't see a reason for it nor do I ever see becoming reality...a shuttle bus is better...
4. That seems to be a New England problem , Busways are overtaking Rail but instead of being cheaper they end up double of the cost and don't attract much ridership. But i'm sure they find a way to thread the commuter rail through New Britain and too Hartford.
5. I think it should be Electric , infact the entire Eastern System should be Electric based off current and future growth projects. I think the system for Hartford should be a mini RER system , Manchester - Bristol line....and the Knowledge Corridor Commuter rail.
I'll add my opinion later...
Northern New Jersey - Lower Hudson Valley & Connecticut Rail & Transit - 2050 Plans
I took sum lines off and added North NJ and NY
By 2025...
Beacon Connection to Brewster
West Shore line
Northwest link
Hell Gate line
West Side line
https://maps.google.com/maps/ms?msid=215312482559953359515.000491cc098e4e5fc7e31&msa=0&ll=41.335576,-73.081055&spn=1.392011,3.348083
