Charlie_mta
- Jul 15, 2006
Go back to page 73 of this thread; we talked a little about the geological challenges of tunneling.
http://written-in-stone-seen-throug...chitectural-geology-of-boston-roxbury_27.html
^This site has the bedrock maps of greater Boston. First map on the page copied below.
The pale tan coloring on the map shows all the glacial mush that's impossible to deep-bore tunnel under. The speckled tan area is slightly rockier debris field...not exactly solid, but bulky enough to support the integrity of Beacon Hill, Brookline Hills, Newton Highlands, etc. That little green toothpick threading from North Cambridge to the Middlesex Fels is a very dense, very hard volcanic dike. Black lines are geologic faults, which you can see cluster around the Charles, Muddy, and Neponset basins. For a reference point you can see they've added all the major water crossings: Longfellow, Mass Ave. bridge, Tobin, etc. Most of the mushiest mush goes 1/2 to 1 mile deep.
Everything we've dug in the tan mush is cut-and-cover, including the Big Dig. The only thing deeper than cut-and-cover ever dug in the speckled tan debris field are the cross-Harbor tunnels and the Charles-Park St. bore of the Red Line through Beacon Hill where the steepest side of the hill afforded soft-digging on a level trajectory without disruption above. And the only place where a TBM has carved out bedrock underneath developed property with no surface disruption is...that little few-blocks-wide toothpick of a volcanic dike from Porter-Davis.
There is nothing else. Tunneling inbound under Mass Ave. is a cut-and-cover job that not only stays in the mushiest of the mush as far south as Huntington, but also has to cross 4, if not 5, faultlines en route. Now consider the price tag NYC is swallowing for the 2nd Ave. Subway. Manhattan is one of the most solid slabs of coastline bedrock on the East Coast. Highly-compressed metamorphic rock with giant seams of marble running through midtown. It's easy to build some of the world's oldest and tallest skyscrapers on that little island for a reason.
If you take 2nd Ave. and re-project the costs to building through mush that requires more mitigation to abutting structures and mitigation to soil movement for all the faults it has to cross...price tag probably soars to half a Big Dig. More expensive than the SL Phase III that was too expensive to build, more expensive than the Urban Ring that was too expensive to build, and possibly as expensive or more than the N-S Link. With way more economic disruption because it's Mass Ave. that's going to be carved up in segments for a full decade. That's totally untenable. I think that would be totally untenable even if we went megaproject-mad and started tearing up streets for all the other officially-proposed downtown transit projects.
I know everybody wants this, but it's beyond the realm of physical possibility. No engineer with a straight face would sign off on a routing so self-defeating on required mitigation. This has nothing to do with political will or not thinking big enough...the very act of trying to construct it and fund all the mitigation required with that construction is patently insane. Its own transit Moby Dick-like pursuit. Civil engineering just doesn't work that way.
The Red Line from Harvard Sq to Davis Sq is a deep bore tunnel, and is in the tan area on the map.
