Heh. MassDOT's own GIS database has a built-in commuter rail Crazy Transit Pitches.
Ehn.
Here's what I see:
-South Coast Rail via Stoughton: Yeah, no. Definitely crazy, at this point anyway.
-South Coast Rail via Attleboro: Marginally less crazy, especially if RIDOT decides to run trains to FR/NB via Taunton and/or if Amtrak resurrects the Cape Codder to dovetail with the CapeFLYER.
-South Coast Rail via Middleboro: This never made sense to me. At least the Attleboro routing has that much more already electrified (though I realize that leads to capacity concerns).
-Commuter Rail to the Cape: clearly not crazy, even if not full time.
-Commuter Rail to TF Green: already done. Surprising that Wickford isn't on here.
-Full service to Foxboro: Really, this is crazy? Especially routed over the Midland Route.
-Bellingham extension: Yeah, this is sorta nuts. But also irrelevant because I doubt it will ever happen.
-Millis: See Bellingham (but probably even less likely).
-Wachusett: Seems to be happening already.
-Gardner: Don't understand how or why this was done before, but it sure as hell looks nuts now.
-Agriculture Branch: I mean... unlikely, but not exactly crazy.
-Commuter Rail to NH: all three seem possible, with the Methuen extension being somewhat less so. It really seems that the greatest impediment are NH politics, and those are inherently ephemeral.
I mean, these are all crazy to some degree or another, especially because the T should not be expanding its commuter rail. But it's going to anyway. So now it's a question of what's crazy within the crazy.
Alright, here's my latest for "Hypothetical Full Build" maps.
I love this. Especially the LRV Urban Ring Connector between Dudley and Huntington Avenue.
Thanks. That connector between (what would then be a subway) Huntington Ave and surface level Dudley is a huge struggle to bridge if you're trying to hit both Brigham Circle and Dudley. Can't tunnel under Tremont to Malcolm X, it's too narrow/too historic. Another version I tried had it going down South Huntington after Brookline Village and splitting off as a streetcar up Heath Street to ride over an NEC deck to RoxXing and then up Malcolm X to Dudley, but it misses Brigham. I suppose you could always have two routings of UR, one that goes up Huntington, and one that ends up at Dudley or up Washington Street, but my transit OCD made me search for a routing that might work for tunneling.
I picked Ruggles Street because I think it got blasted for NEU urban renewal, so could be tunneled under (also gives a connection to Orange at Ruggles). I also assumed that Whittier, and the land behind the Madison School could be cut and covered. The positioning of the portal would be up for discussion, but I put it a little west of Dudley, although that street probably doesn't have the space for it. That might be the biggest issue for it, unless the T buys one of the vacant lots around Marvin or Vernon street for a portal. I also don't know if that underground river somewhere around NEU precludes the tunnel from Huntington. It was the best solution I had though, given my layman's knowledge of the underground environment.
If Marvin St were closed to traffic (at least the eastern half of that block, but maybe the whole block) could that be used as a portal?
Would a 28x deal past Dudley to, say Franklin Park Zoo, or Columbia Road really be that bad? A restored E or A would be longer wouldn't it? Is it wholly longer than the current B? Honestly it's too bad that it's too far to get to Mattapan, if only because Blue Hill Ave is literally built for streetcars. I'd imagine you'd easily fit a median reservation along Blue Hill. But, I figure if Red gets to Mattapan, plus Indigo MUs running through Dorchester having a slow-ass Green streetcar down Blue Hill Ave would be redundant. I thought a shorter jog down Warren to Seaver Street or a few hundred yards further to the Park might be more useful.
Big Dig 93 north of the River Charles to the River Mystic.
Shouldn't all DMU service ideally be subway fare?
