Has anyone really studied Newport as part of intrastate service, instead of part of a SCR extension?
Formally it's been studied as a seasonal Aquidneck Island Budd RDC shuttle upgrading the existing tracks. Everything beyond that is placemarked in the RIDOT State Rail Plan as "TBD" for South Coast Rail reaching some sort of resolution.
I can't imagine you can get across Narragansett Bay to Quonset, or to the E. Bay Bike Path running through Bristol to E Prov. (There never was a historical connection there, as I recall.) That path is too physically disconnected on both ends to even contemplate, unless you figure out two very expensive connections on both ends. Though, I think you could make the density/ service argument for that set of towns to work.
Not only that, there was never historically Warren Branch service continuing to Newport. That was electrified service using rickety wood-body ultralight EMU's because of the severely weight-restricted Slades Ferry Bridge. No steam allowed, wires ended at Fall River Depot. NYNH&H thru service went the long way around via Attleboro-Taunton.
Early 90's. But RIDOT has plans to reactivate on-file in the State Rail Plan.(Also, when was the last use of the street running track on Allens Ave/1A?)
