My plan reaches areas that would likely consider it a hassle to reach mass transit. Chestnut/Western is a dense area that’s on the other side of Lynn and intersects with a couple bus lines. You’d like see it pull a great deal of commuters from the East Peabody
I applaud you for thinking in terms of "Where Transit Needs To Be Built" rather than "Where Transit Is Easy To Build". That's always an important perspective to have in these conversations, especially given that there is overwhelming political and institutional pressure that creates bias toward the latter.
That being said, there still needs to be a balance, and I tend to agree that building a tunnel in the North Shore seems unnecessary. The Eastern Route ROW as-is provides an excellent spine for local HRT and express electrified mainline rail; the missing piece is a more robust feeder bus system, the bones of which are currently there, but which needs major frequency enhancements (and probably a few bus lanes), so that it creates a seamless "turn-up-and-go" experience for riders.
Remember this thread is “Crazy” transit pitches. As long as there’s a legitimate purpose for it - that’s the only requirement (or am I misunderstanding?)
The goal of this thread has drifted over the years, but these days this thread is typically used for proposals that are largely absent from the "official" planning discourse but which still stand up under rigorous scrutiny, at least from a technical and value perspective (we tend to discount, though not ignore, the short-term political challenges here and likewise the "raw" price tag -- though not the "bang-for-buck" efficiency price tag).
For example, extending the Green Line from Union to Porter and then to Watertown: it's not on any official plans, and hasn't been seriously floated in the public discourse, mainly because there's so much focus on just getting the current GLX built. But the ROW is largely extant, the corridor is similar to others that have seen success, and it wouldn't require massive capital investments like tunneling. It's "crazy" perhaps in a political sense, but not in a technical one.
That contrasts with a thread called "Reasonable Transit Pitches", which in my eyes has evolved into "Proposals That Could Be Implemented In The Next 10 Years" as well as "Proposals That A Politician Could Make And Not Get Laughed Out Of The Campaign." A lot of the current discussion in there focuses on BRT concepts, such as my proposed Navy Line.
Then there is the God Mode thread, which I think is best suited for the ideas you're raising here. Feasibility -- both technical and political -- is pretty much ignored there, and it's a valuable space for letting the imagination run wild.
There's definitely cross-pollination across these threads -- for example, a high-flying idea in the God Mode thread might get the gears turning, as someone realizes, "Hey, with a couple of tweaks, that actually could turn into a buildable idea!" And sometimes an idea is raised here in Crazy Transit Pitches that, on further examination, doesn't quite work, so the convo gets shifted to God Mode, and so on.
Don't share your opinion on the lack of need. There is a fairly decent gap in the financial district where most other parts of Downtown area have stations within a minute or two. ALTHOUGH that could be up for debate I'll admit. What I don't understand is how you don't see a need in the North End. That neighborhood (along with Charlestown - unless you count CC) is vastly underserved. I think a North End rail station would be very popular and would go a long way to the never ending parking chase on summer / weekend nights in the North End.
So, I am less skeptical of the usefulness of rail to the North End than some other folks here. The prevailing standard for stop-spacing in the core is a 5-7 minute walk between stations, and that drives (and is driven by) a fair number of local behaviors and other factors. One of those is the idea that you only have to walk ~3-4 minutes to reach your destination from the nearest T stop. Next to that, a 10-minute walk one-way is a significant difference.
I think you are right to raise (in a separate post) that a 12-minute walk becomes significantly less hospitable when it's cold, raining, snowy, or if you have some sort of limitation on your mobility -- whether that's groceries, children, or a physical difficulty. Again, not impossible by any means, but discouraging.
By the 5-7 minute walkshed metric, that would point to a rail station somewhere around the intersection of Prince and Hanover. (Ironically, 115 years ago, this was a proposed station location for what became today's Blue Line subway.)
^ Those are the pros, and I agree they're not trivial. Let's talk about the cons.
First, let's talk about tunneling. At this point, I think there are really only two scenarios where tunneling makes sense for transit in Greater Boston:
1) There is a segment where a very short tunnel will significantly increase the operational efficiency of a new line. I can't really think of a good example of this, but in principle it could work.
2) A tunnel will have transformative impact across the entire system. Some examples include the North-South Rail Link, the Blue-Red Connector, and (debatably) subways under Comm Ave and Huntington Ave for the B and E Lines respectively.
A subway through the North End fails both of those tests. Simply put, we need to be able to say why such a subway would be good for the whole system, not just the North End.
Second, there's the impact on the rest of the Green Line. I'm not going to belabor this point, but consider:
- the impact of diverting service away from the core section (including the Red Line transfer at Park!)
- how you're going to connect at Boylston (discussed above re Essex Street)
- how you're going to hook in at North Station (remember that you need to thread through the Orange Line, the future NSRL, and the Central Artery Tunnel in order to reach the Green Line tunnel -- that's a tall order, and add on top the need to have a flying junction so as to not create delays with a flat junction)
- Why does the 4 get low ridership?
- Note that according to the Better Bus Profile, the 4 is mainly used by North Station commuters heading to the Seaport, which tracks with its ridiculous routings, and suggests that it may not be representative of the real transit potential of the North End
- How many people would go to the North End if transit existed but currently don't?
- How many people currently go to the North End would use transit if it existed?
- How many riders might be diverted from tourist trolleys?
- What kind of riders would use transit to the North End? And what is their tolerance for travel times and wait times?
(For what it's worth, if you feel that there's a must-have need for rail rather than bus in order to attract riders, one could consider a "heritage trolley" line -- perhaps South Station-Greenway-Aquarium-Commercial Street-Hanover Street-Haymarket. Or even just up and down Hanover Street from Haymarket. You could also consider a westward extension via Cambridge St -- if Blue-Red construction ends up closing Bowdoin, there would be a sizable gap.)
