This is what the NSRL 2019 reassessment says in terms of tunnel throughput for the 2-track and 4-track builds:
We're going to have to revolutionize our on-time practices to even get a 3.5 minute per direction frequency, because that target is well shorter than the T's schedule padding for technical "on-time" status and it would be conflict-city (even going one-way) if American slop ops--even much less than we currently put up with--were the rule. Not only do you need 100% systemwide level boarding, but a lot of grade crossings are probably going to have to go in order to achieve that level of schedule certainty all the way from 495-land for orderly procession through the tunnel. It's considerably more difficult with an open system like the Purple Line compared to dispatching a closed rapid transit line, and while other countries do it don't sleep on the complexity of a wholesale systemic retrofit while we're still trying to substantially expand that system with more and further-flung lines.
I agree...this is a bad all-around application for mainline rail. LRT/HRT, and don't pussyfoot around it. NSRL does great things, but its focus gets diluted by carrying more intra-128 lines in a completist's universe than the ones (like Fairmount) that absolutely have to be on the FRA network for good reason. That's why Needham will be long gone by the time it comes to fruition, and converting Reading to its originally intended OL extension becomes a potentially significant decision afterward.
EDIT: And also what EGE said...the walking/escalator distance for line transfers from the claustrophobic and off-center underground stations is going to suck by necessity of the tunnel trajectories we have to work with, so if trying to link neighborhoods with the intent of facilitating easy transfers that's going to weight your mode choice heavily in favor of rapid transit over Regional Rail.
